Can Konica Minolta Printer Freeze?
  • m_ridzon
    • Jan 2023
    • 16
    #16
    Re: Can Konica Minolta Printer Freeze?
    Originally posted by copyman
    I would not recommend that end user remove the MFP board.
    Thanks for that feedback. It was going to be my next question, on whether I should remove the board or not.
    • ronny2502
      • Mar 2020
      • 79
      #17
      Originally posted by m_ridzon
      Under normal conditions, how would one know that the backup battery is near end of life? And how would they preemptively deal with it to avoid a mess?
      There is no message giving a hint battery is near EOL. - Users get aware, that battery is empty, when machine is powered off for any reason (and powered on again).
      Ro
        • 23008
        #18
        The way you test that battery is to connect a volt-ohm meter to the battery and read the voltage starting with power ON. The battery is 3vdc, but is maintained by the 5vdc logic voltage. It will read 5.0vdc with power ON. The moment the power is shut OFF the battery should drift down to 3.0vdc. At 2.85vdc, there isn't much time left before you'll lose settings. Somewhere between 2.6 & 2.7 vdc settings will be lost.
        To save yourself trouble of trying to restore lost settings, remove the PWB and measure the voltage. If it's getting low, solder another battery alongside parallel, so there is always voltage. Then you can de-solder of clip off the old battery. =^..^=
        • techsxge
          • Jan 2022
          • 660
          #19
          • techsxge
            • Jan 2022
            • 660
            #20
            By the way, in the users guide konica specifies the to-be-used temperature ranges:
            • copyman
              Owner / Technician
              • Sep 2005
              • 4712
              #21
              The battery # is CR2477 lithium cell 3V. It's thicker then the CR2032. Almost looks like it's 2 batts together but it's not.
              Not sure if OP mentioned how long machine is going to be stored. There are a lot of factors to be considered depending on how long in storage.
                • 37515
                #22
                Standard for most modern MFP. Does not include storage.
                  • 37515
                  #23
                  • techsxge
                    • Jan 2022
                    • 660
                    #24
                    I'd say if you cant have the machine operating outside of these temperature ranges, you should also not store them.
                    • femaster
                      • May 2011
                      • 1508
                      #25
                        • 37515
                        #26
                        It is not the static voltage of lithium ion batteries that is adversely affected by low temperatures. It is the length of time that they can support a load.
                        ScienceDirect
                        This is why so many electric vehicles got stranded during cold weather.
                        • techsxge
                          • Jan 2022
                          • 660
                          #27
                          ScienceDirect
                          also the chemicals inside can "clog up" and change their stance/state (? Is that the correct word?) which can destroy the battery entirely and also all components powered by it possibly.
                          • m_ridzon
                            • Jan 2023
                            • 16
                            #28
                            Well folks, I have good news! I know this thread is old, but I'm happy to report back that the printer sat in storage through two winters, one being quite cold (roughly 0°F for a while). Last week, I fired it up and connected it to my network with absolutely no issues! Thanks for your help and feedback!
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4712
                              #29
                              Glad it worked out. Good ole BizHubs keep on ticking......
