B005 Code on C258 | Same Fax Kit Works on other machines
  • captainrva
    • Oct 2014
    • 100
    Hello, I have 2 C258's and no matter what Fax kit I put on them I get a B005 error or no error and the fax has no initialize button in service mode. All the fax kits I have tried work on other 8 series copiers. Any help is appreciated.
  • kingarthur
    • 1399
    Re: B005 Code on C258 | Same Fax Kit Works on other machines
    i'd look at either the connectors that the fax plugs goes into - or the wiring loom
    • Synthohol
      Certified Konica Expert
      • 5922
      ive had brand new machines come in with those 2 ribbon cable wires unplugged still in the loom.
      • Ziggy
        • Feb 2018
        • 815
        Not sure if this would cause your problem but it wouldn't hurt to make sure the marketing area is correct
          • 15069
          Are you sure it's a B005? I can't seem to find that fax error in the manual.
          • femaster
            • May 2011
            • 1527
            I can't speak for the B005 error, but the second part, no initialize button in service mode, I've seen on a machine where the hard drive was "unset".
            • strider5555
              • Jun 2008
              • 96
              B005 error. FAX board error 5 (No fax board is installed. Mistake in installation, defective HW). I had this on a 4e series once. What ended up fixing it for me was plugging it into the Fax 2 plugs, I'm assuming the wiring was reversed for some reason at the main board or at the fax connectors. Try this, maybe it will work?
              • rrrohan
                • Sep 2011
                • 1977
                is the switch on fax board set to line 2 by mistake?
