C658 Error 30-3
  • fuserdotcom
    • Jan 2024
    • 6
    [Error Code] C658 Error 30-3
    Good Evening Gents,
    I have 2 Konica C658 with the same error 30-3. It seems the paper get stuck causing the jam.
    We've cleaned all the trays with no luck.
    I've searched in youtube and there is a video about cleaning a sensor but the Konica showed in the video is slightly different from ours and I was unable to locate this sensor for cleaning.
    I've attached a pic to show where the paper get stuck.
    At the moment both printers cannot even print 1 sheet.
    THANKS for Support.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4747
    Re: C658 Error 30-3
    Originally posted by fuserdotcom
    Good Evening Gents,
    THANKS for Support.
    Clean or replace the registration roller bushings. That black roller above where paper stops should move freely.
    • kingarthur
      • 1383
      Re: C658 Error 30-3
      I agree with copyman - had a few of those fail, if you replace the bushings, replace the rubber and metal rollers - when they're bad, they're a nightmare to remove the old bushings
      • allan
        RTFM!!
        • 5462
        Re: C658 Error 30-3
        Had a 558e with a near seized driven roller. I just clean the bushing in that case. If the roller runs freely go to sensor check and see if the senor output changes state when actuated. If not the sensor or sensor supply is faulty. The actuator can get stuck but will show a PE(permanent error) if that is the case. Last trace the connector for the clutch and shutter back the the front side board and check if 24V is there.
        It will always be 24V on the clutch wire until the MOSFET or MCU pulls the current thru to ground to activate the clutch. If no 24V then fuse 2FE on MFPB is blown out. Long shot but look at this thread.
        J3003 C558...
        Whatever
        • tsbservice
          Field tech
          • 8040
          Re: C658 Error 30-3
          Good Evening Gents,
          THANKS for Support.
          Try to cheat side door sensor and start copy from first tray and help the sheet to make it somehow to registration rollers.
          If clutch is not working at all go Allan's way, if it's trying but rollers are binding do what other guys suggested.
          Good luck
          • allan
            RTFM!!
            • 5462
            Re: C658 Error 30-3
            Good luck
            That is a good way to check. Remember to engage the fuser as well or you will get C3102.
            Whatever
            • Ziggy
              • Feb 2018
              • 795
              Re: C658 Error 30-3
              Found this online, hope it helps
              • fuserdotcom
                • Jan 2024
                • 6
                Re: C658 Error 30-3
                Good Day Gents,
                I'm amazed how good people give different suggestions on the topic, Thank You!
                Actually we managed to clean the black roller as suggested in the first place and the machine started to print correctly, it was stuck.
                All other suggestions are well appreciated and noted if necessary in the future.
                Thank You Again for Your Valuable Support!!
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4747
                  Re: C658 Error 30-3
                  Good Day Gents,
                  Glad you got it working. Thanks for reporting back.
