c250i stuck on boot screen
  • Scarekrow
    • Feb 2012
    • 83
    Hello,
    I have a Konica C250i stuck on 25%- 50% boot screen, I have tried to do a FW and recovery tool but the machine does't respond, just stays on the boot screen with the black dot top left corner, waited 15 mins, nothing, it's quite new machine around 10k total and has the Q8 FW fitted.
    Any ideas on how to fix this? I don't have any spare boards either to try out with.
  • Ziggy
    • Feb 2018
    • 791
    Re: c250i stuck on boot screen
    Originally posted by Scarekrow
    Hello,
    If you have tried the GXX firmware and it doesn't take it I would start by replacing the CPU board
    • Max
      • Oct 2011
      • 561
      Clean then format the ssd in the computer/using usb adaptor. Boot up with Q9 firmware. Works 9 out of 10 times. If not probably a CPU board
      • Scarekrow
        • Feb 2012
        • 83
        Do you mean remove the storage board, connect it to a PC and format it there? are there any instructions for doing this as I have never done that before so I don't know what adaptor I would need. What, if any, data would I need to re install by doing this?
        • aberock
          • May 2022
          • 127
          Hi Sir ,
          can i get a copy for Q9 firmware ?
          my email : coolmodelcompany@gmail.com .
          Thanks.
          • plus-COPY
            • Aug 2023
            • 32
            Hi,
            If you can't save your settings and address book, I wouldn't recommend formatting or doing anything with STRGB.
            Check if any firmware or utility/tool is loaded
            bizhub 450i/360i/300i - AC770Y0-F000-GXX-20.exe
            • Scarekrow
              • Feb 2012
              • 83
              Originally posted by plus-COPY
              Hi,
              It won't boot up even with an GXX tool I was told it's the SSD board that I need to replace so when it comes I will fit that, service manual says.
              Actions after replacement of the board
              1. Turn ON the main power switch.
              2. Check the firmware version of the SSD Controller.
              I.6 Firmware Version
              3. If the firmware version of the SSD Controller is not the latest, upgrade the firmware.
              FIRMWARE
              4. The machine will reboot two times by itself. Wait until the trouble code (C-D3C0) screen appears.
              5. [Recover Data] appears on the trouble code screen, touch [Recover Data] to start the recovery of data.
              6. If there is any data retrieved with backup utility, conduct the recovery of data.
              • allan
                RTFM!!
                • 5462
                Strange question but does the machine accept a print job in that 25% booted stage? Had it where the scanner caused the machine to hang there but it would accept print jobs so you should be able to ping it. Figured out it was the scanner after dissing functions by unplugging sections. It booted up without the scanner allowing me to isolate it while looking for the issue.
                Long shot...
                Whatever
                • tsbservice
                  Field tech
                  • 8035
                  Long shot...
                  Nice catch.
                  It's either storage board most likely or CPU board uncommon.
                  • Scarekrow
                    • Feb 2012
                    • 83
                    Nice catch.
                    Yes I unplugged ADF anf the Fs-533 and tried to boot again, I have a New SSD on the way so will try that when I comes in,
                    • allan
                      RTFM!!
                      • 5462
                      I mean the SCDB connection to the control board to dis the scanner not just the ADF..
                      Whatever
                      • Scarekrow
                        • Feb 2012
                        • 83
                        No I didn't uplug anything directly from the main board, I did take out and clean connections to the storage chip and cpu board and re assembled
                        • Albonline
                          • Sep 2008
                          • 1153
                          adaptor needed m2 to usb 30$ us amazon . I use a freeware called test drive. its easy to use and works , saved a lot of ssds/strgbds with it.
                          • tsbservice
                            Field tech
                            • 8035
                            Would you mind to share the link as I search and failed to find this freeware?
                            • Albonline
                              • Sep 2008
                              • 1153
                              TestDisk Download - CGSecurity
