Is a Bizhub 320gb HDD upgradable to SSD?
  • captainrva
    • Oct 2014
    • 100
    Can't seem to find the replacement drives we used to get on amazon anymore so I was wondering if anyone had success just upgrading the old HDD's to a 2.5" Solid State Drive? Would probably stop a lot of headaches with the old drives just dying or getting damaged in transit.
  • Albonline
    • Sep 2008
    • 1150
    Re: Is a Bizhub 320gb HDD upgradable to SSD?
    ssd will work, but must be at least as large as the drive you are replacing.
    • Jumping Jack Flash
      • Jul 2009
      • 66
      I also think it's possible, but you have to find a type of SSD that has the SATA III communication protocol,
      because that's what is in copiers.
      The new SSDs communicate in PCIe, NVMe, etc. modes.
      Additionally, they require other SATA drivers and adapters.
      • Synthohol
        Certified Konica Expert
        • 5824
        320g wd - Google Search
        plenty there
        • Ziggy
          • Feb 2018
          • 732
          I have successfully used 500gb SSD is eight series several times . I get them from Amazon for about $40.00
          PNY CS900 500GB 3D NAND 2.5" SATA III Internal Solid State Drive (SSD) - (SSD7CS900-500-RB)
