Bizhub C250i annoying noise
  • mandongo
    • Mar 2021
    • 32
    [Misc] Bizhub C250i annoying noise
    Hello friends!
    I have one Bizhub C250i with strange noise (mouse like).
    Can someone tell me what can cause this sound and how to get a rid of it?
    Thanks in advance!
  • Duplicator
    • May 2022
    • 245
    Re: Bizhub C250i annoying noise
    When it's squeaking, does it stop when you open the front door?
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • KMFLT3CH
      • May 2017
      • 207
      It's the exit rollers.
      i-Series noisy exit rollers
      • mandongo
        • Mar 2021
        • 32
        Thanks for the reply!
        Sorry to ask maybe a stupid question, but I didn't understand where exactly to apply the lubricant - on the rollers, on the shaft under every roller, or in the ends of the shaft?
        • Synthohol
          Certified Konica Expert
          • 5737
          everywhere in red gets a drip of tufoil lubeit-8 with a needle applicator from me.
          • copytechtrouble
            • Nov 2020
            • 91
            Originally posted by mandongo
            Hello friends!
            Thanks in advance!
            the exit rollers can be responsible as well as the waste toner hopper.
            in the case of the hopper, apply PTFE lubricant to these areas
            • kingarthur
              • 1301
              I normally strip the unit down completely and lubricate everything
              • KMFLT3CH
                • May 2017
                • 207
                For this particular model line, the shaft where the lower idler rollers ride. The ones along the bottom in my video. If you run the exit rollers like mentioned you can lubricate them and work it in.
