KM-5052ci fuser
    • 23009
    KM-5052ci fuser
    So I had this 5052ci this week with J4214, J4204, J4203 codes. I managed to get the reports printed off before it started jamming again. Then it pulled a C2300 (fuser drive error) that would not clear.
    I checked U030, trying to run the fuser motor, but it errored out before I could get the simulation started, even with a door left open during bootup. In U031 there isn't a simple way to check the rear belt rotation sensor or the front belt rotation rotation sensor. The rear sensor runs to the paper feed board > paper image board > engine board. The front sensor runs to the fuser PWB > paper feed board > paper image board > engine board. The only place those signals are reasonably accessible is at the paper feed board (pushing straight pins into the connectors). The fuser motor does run up during initialization, the rollers do turn, and the pressure is applied correctly. I could not tell if the pulse wheels turn. The harness pins out good. (152K total prints, ~6K color)
    I ordered up the fuser and it did fix it. So here's the question: It really bugs me not knowing what failed. It's really convenient to swap out units ... but I'd really like to know what failed here: rotation sensors? fuser PWB? pulse wheels not rotating? By the time it coded it was a hard failure. It should be easy to catch the cause of a hard failure. So I'm asking. =^..^=
  • Santander
    • May 2009
    • 768
    Re: KM-5052ci fuser
    Agree with your assessment. since replacing the fuser assembly resolved the issue, would suspect that it was binding up and causing the code. These units track so many variables, it would be easy enough to pinpoint the actual malfunction. But I guess I am from the old days where you identified a problem within a unit and resolved it by replacing the part and not just the complete assembly.
    • Ropariva
      • 680
      Re: KM-5052ci fuser
        • 23009
        Re: KM-5052ci fuser
        I did notice that the foam rimmed cap at the front of the belt (that drives the pulse wheel) fit more loosely than the one at the rear. I can imagine the front pulse wheel slowing ... throwing off jam timing and motor speed calculations. It's logical. =^..^=
        • Geo
          • 662
          Re: KM-5052ci fuser
          On a side note.....Any chance that that these fuses will ever go their rated life?
          • Ropariva
            • 680
            Re: KM-5052ci fuser
            • Geo
              • 662
              Re: KM-5052ci fuser
              On multiple fusers ,the coating on the heat belt wore out where the edges of the paper contact the belt...Seems to happen more on color boxes , 250 -350 K.
              Did you notice how soft the coating is , fingernail easily scrapes the coating off.
              As for the charges....Yep...One would think that after 4-5 +years they would figure it out...unless they are are not fixing this problem on purpose.
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1888
                Re: KM-5052ci fuser
                H178 addresses the error code.
                I013 addresses the pads coming out causing C6600 & C6770
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                  • 23009
                  Re: KM-5052ci fuser
                  Thanks Tony.
                  • Tulsa
                    • May 2014
                    • 20
                    Re: KM-5052ci fuser
                    I appreciate you trying to track down that issue. I heard other posters questioning the viability of this particular fuser. We have replaced 4 units in the past 10 days in units less than a year old. Of the 4 fuser replaced only 1 mfp had more than 100k. That was 110k. The other 3 copiers had 84k, 88k, and 93k. The fuser had literally blown up. It looked like the fuser had a million copies, throwing codes and locked up. I am shocked to hear someone say that they have gotten 600k. Not too long ago we went down this road with 6550's. Hopefully this one will not take 9 revisions, and the infamous papergauge.
                      • 23009
                      Re: KM-5052ci fuser
                      Does anyone have a field solution (read MacGuyver) for this situation? Had I thought of it at the time, I might have tried smearing some silicone tub & tile sealant onto the outer surface of the heater sleeve, gluing the sleeve to the cap. =^..^=
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        Re: KM-5052ci fuser
                        Why can't manufacturers admit the whole advanced fusing system is an abject failure. Induction, belts, retraction motors... blah blah blah. All for what? Energy star rating? No press roller flat spots?
                        Give me the old fashion Falcon fusers any day.
                        • Geo
                          • 662
                          Re: KM-5052ci fuser
                          Have you noticed how soft the coating is on the heat belt..very easy to remove with your fingernail..No way can this soft material last 600K.
                          • copier tech
                            • 8174
                            Re: KM-5052ci fuser
                            Kyocera will replace any unit under warranty if it fails before life so no need to try & repair, they will modify the fuser if it becomes a common/known issue.
                            • Ropariva
                              • 680
                              Re: KM-5052ci fuser
                              Just replace and warranty claim.
