Kyocera 7002i thick solid black line
  • tsbservice
    Field tech
    • 8036
    #61
    Re: Kyocera 7002i thick solid black line
    Originally posted by Necrocannibal
    Thank you, I assumed that was it from my research. We replaced that board last Friday and so far haven't had any call backs but it is too early to tell. I'm going to wait two weeks before calling it repaired.
    Sent from my SM-N986U using Tapatalk
    Hey, just seems you're doing the best you can.
    Good luck solving this!
    • Necrocannibal
      • May 2008
      • 212
      #62
      Thanks. I'm hoping the Front PWB was the culprit, we've replaced almost everything else at this point.
      • Necrocannibal
        • May 2008
        • 212
        #63
        Ok well they didn't call us back for over a month after the Front PWB but they said it is back, no clue what to do for this thing at this point.
        • masterchill
          • Jul 2005
          • 100
          #64
          Have you tried the laser unit? We had something like this and everything was pointing to a high voltage issue but after replacing everything we finally tried the laser and that ended up being the issue.
          • Necrocannibal
            • May 2008
            • 212
            #65
            No that is the one thing we haven't tried, I actually ordered a new drum and developer today because even though they are newer we haven't tried them since this problem started. If they don't work we can try the laser.
            • KYO_OEM
              • Aug 2011
              • 725
              #66
              meanwhile we have had several cases like yours and diff. solutions needed.
              DK unit, dk drive incl. motor, transfer belt, complete conveying unit, laser, etc.
              Now we have had 2 cases with missing clip on belt shaft.
              Without this clip we got sometimes grounding problem.
              System now is working fine since 1 month.
              • Necrocannibal
                • May 2008
                • 212
                #67
                [ATTACH=CONFIG]47485[/ATTACH]
                Thanks for posting this, I'll have the tech take a look at this when he goes back to put in the new drum and developer.
                • Necrocannibal
                  • May 2008
                  • 212
                  #68
                  Well the tech went out today and found that there was no clip there so he put one on it and we are waiting to see what happens. That belt came from Kyocera new just a couple of months ago so it has to be something that isn't being put on when they are manufactured. We may have been chasing a problem that Kyocera caused.
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    #69
                    Incredible. If this holds you owe KYO_OEM a beer.
                    • KYO_OEM
                      • Aug 2011
                      • 725
                      #70
                      only 1 beer???
                      • Necrocannibal
                        • May 2008
                        • 212
                        #71
                        If it fixes the issue I'll PayPal him money for a 6 pack or fifth, whatever his preference is. Lol
                        • Necrocannibal
                          • May 2008
                          • 212
                          #72
                          only 1 beer???
                          [ATTACH=CONFIG]47545[/ATTACH]
                          Lol, I'll do a 6 pack or fifth.
                          • KYO_OEM
                            • Aug 2011
                            • 725
                            #73
                            i don`t have paypal and i am located far away from Memphis/ USA!! (4680 miles...)
                            We are all technicians i am proud to be in assistance to other technicians.
                            Hopefully system works well now!
                            • tsbservice
                              Field tech
                              • 8036
                              #74
                              Amen to that Brother! Rep ⬆👍
                              • Necrocannibal
                                • May 2008
                                • 212
                                #75
                                Well thank you so much for helping!
