Kyocera 2551Ci
  • GeorgeBest
    • Jul 2009
    • 526
    Kyocera 2551Ci
    Hi,
    Got this Kyo TASKalfa 2551ci back from a customer.
    Now I need to clear all settings on this one . .
    Is there a way to set it to factory settings?
    Normally I do Ricoh's
    anyone?
    Thanks in advance, would appreciate it . .
    gr George
  • Samanator
    • Sep 2017
    • 579
    Re: Kyocera 2551Ci
    This is something I made for people to use when I'm not around to clear a machine that is coming in (used machine) or going out (lease return):
    Clear Out Machine Data
    *These prosses are in order of the time they take. Shortest first.
    SYSTEM INITIALIZATION
    System Menu > Adjustments/Maintenance > System Initialization > Login into the machine > Yes
    The machine will reboot itself
    FORMATTING THE HD
    Log into Maintenance Mode (10871087) > Input 24 > Start > HDD Format > Full > Execute > Start > Reboot the machine
    DATA SANITATION
    System Menu > System Network > Login into the machine > Data Security > Next > Run Immediately > Start > Yes
    This should work for most all Kyocera machines. I hope this helps.
    • GeorgeBest
      • Jul 2009
      • 526
      Re: Kyocera 2551Ci
      Thanks!
      unfortunately I cannot come into the System menu, because when powering the machine I get an display that says:
      "MYQ, myq embedded terminal 7.3.3.1, SEVER OFFLINE"
      It gives no reaction whatever . .
      Is it possible to disable this screen?
      Thanks .
      FORMATTING THE HD
      DATA SANITATION
      • copier tech
        • 8172
        Re: Kyocera 2551Ci
        Originally posted by GeorgeBest
        Thanks!
        Thanks .
        Disable the MYQ App first.
        • GeorgeBest
          • Jul 2009
          • 526
          Re: Kyocera 2551Ci
          and how do I do that?
          • Samanator
            • Sep 2017
            • 579
            Re: Kyocera 2551Ci
            I know this may sound stupid, but even on that screen requesting the MYQ server, have you tried 10871087 with the key pad?
            I know many times with C codes I can still get the machine into service mode.
            Just a shot.
              • 23009
              Re: Kyocera 2551Ci
              Just a shot.
              Along the same lines: On the older Kyoceras, boot to "Door Open" indication > 10871087> close door
              Sometimes works. =^..^=
              • yakyitz
                • 245
                • KYO_OEM
                  • Aug 2011
                  • 721
                  Re: Kyocera 2551Ci
                  additional way:
                  MyQ application would stored on HDD
                  Shut down the system, remove the power plug from the wall outlet, unplug HDD, start up the system again and you get C0640
                  Enter 10871087/ run U024/ execute/ Start
                  Shut down system, remove the power plug from the wall outlet, plug in HDD again
                  Start up system again
                  System will run HDD format during this start up
                  MyQ removed!!
                  Finally you can run data sanitization by system menue.
                  • GeorgeBest
                    • Jul 2009
                    • 526
                    Re: Kyocera 2551Ci
                    Thanks for all the input!
                    Its working.
                    gr George
                    Originally posted by KYO_OEM
                    additional way:
                    MyQ removed!!
                      Re: Kyocera 2551Ci
                      additional way:
                      MyQ removed!!
                      Good one.
