Commonly faced issues with Kyocera Taskalfa 2553 Ci
  • alfanex
    • Jul 2025
    [Misc] Commonly faced issues with Kyocera Taskalfa 2553 Ci
    Can anyone update me with the common issues that they have face with the Taskalfa 2335 Ci and the remedy for the same if any?
    • 23007
    Re: Commonly faced issues with Kyocera Taskalfa 2553 Ci
    This should cover it:
    Kyocera 2-series Question
    • Ropariva
      • 672
      • Bob-Sponge
        • May 2024
        • 14
        I have a problem with a TA 2553ci . Everything goes well in simplex printing, but duplex printing finishes in a jam . I have cleaned all rolls, How can I diagnose if a sensor is defectctive or motor. I don't have any error code and would like to localize the problem. I have access to maintenance mode.
        Thank you in advance
          • 23007
          Get the jam code.
          • KYO_OEM
            • Aug 2011
            • 713
            if you have access to maintenance mode you can take out the eventlog and you`ll see the jam codes.
            • Synthohol
              Certified Konica Expert
              • 5824
              i dont know why you picked a 4 year old thread to piggyback on, you could have started your own?
              print the maint report and look at the event log, its one of those 15 pages
              • Lunatech
                • Oct 2012
                • 206
                Or just look at the panel when it is jammed.
