Kyocera 4501i Dumping Toner
  • kleankopy
    • Feb 2016
    • 116
    I have at least 10 machines that dump toner all over the registration roller. Have just as many that run fine.
    All of these machines have had new dv units replaced anywhere from 30k to 120k before they start doing it.
    I have tried complete pm kits on 4 of them but it didnt help.
    Also updated all firmware and OEM toner only.
    We clean and pages come dirty again after 10k
    Anyone else see or have this issue.
  • Ropariva
    • 701
    • kleankopy
      • Feb 2016
      • 116
      Re: Kyocera 4501i Dumping Toner
      Have not vac out the dev chute and toner disposal filters at the rear.
      I will give that a try.
        • 23010
        It's not a cure, but definitely prolongs the interval. =^..^=
        • Ropariva
          • 701
            I don't about y'all IF I get a call about PQ/CQ after getting the problem(s) explained to me ..and I get my test sheets out.
            I strip the machine of Toner/Dev/PCU/PCDU/Fuser and any 'tray' type parts Duplex etc.
            Then I vac the HELL outta the machine... then gently BLOW the paper path that can't be vac'd
            Inspect each part going back in for wear/build up/nicks/dings make note
            and repeat.
            yeah... sounds a little anal BUT.. how many time have you skipped those step and had to tear it all out again, just to replace a failed dev unit?
            • Scottb
              • Apr 2013
              • 308
              Once you remove the registration assembly and vacuum it out and the copier frame, and the duct at the rear of the machine. You should replace all the duct seals that can be found in the parts book Fig 13 this will reduce the amount of toner dust.
              • KYO_OEM
                • Aug 2011
                • 727
                look here to find all areas for cleaning
                • Samanator
                  • Sep 2017
                  • 579
                  Thanks for the bulletin KYO_OEM. A big help to show others.
                  • KYO_OEM
                    • Aug 2011
                    • 727
                    look for this additional bulletin for checking if seal modification would done by factory
                    • fishleg
                      • Mar 2009
                      • 426
                      Even the new models still suffer from this just check it if you open the door and notice the transfer roller section looks covered in toner. I think it's just the speed of the machine that does it. Shame all the filters are on the back of the machine. I have noticed the new ones have a vibrating plate in the filter which I've never seen before but I guess it's to keep the filter from clogging up as much.
                      • kleankopy
                        • Feb 2016
                        • 116
                        After cleaning all the filters and the ducts and running for 2 weeks went back to them all and their running a lot cleaner now.
                        Thank you to all who helped.
