Did you move or replace any of the Drum Units? How about the Laser have you moved or replaced the unit. Seems that your black drum may not be installed correctly. Have you done anything with the ITB?
Larhal
If all else fails read the Service Manual!
If that fails, meet me at the pub and we will discuss it.
no I didn't touch anything other than black the other colors are off. the black is printed in the right position....
Ok what did you originally do with the Black drum unit? You say the other colours are off but you disturbed the Black drum unit. That would indicate that the colours are OK but the black is off. why did you remove the black drum unit, what was the problem?
Try removing and reseating the Black drum unit.
Lets keep this simple and investigate what you have done and the reason for it. Maybe this will lead us to resolving the problem.
Larhal
Run U468 / “Initialize“ / “Execute“ and press [OK] key
Check if all values of [Auto] and [Manual] > ”0”
If values = “0“>>enter U001 and press [OK] key / if other values > repeat U468
No other changings, no copies/ no printouts during this procedure!!
Finally run System menu > adjustment/maintenance > 2. page >
1. Calibration
2. Color Registration/ manual/detail
