8003 pin holes / dots
  • Dark Helmet
    • May 2009
    • 858
    Howdy folks, we have seen this on lots of the 7003/8003 machines. Tiny dots on the surface of the drum leaving marks on the page. The Transfer Belt wipes out the drum. You have to change them as a pair or it does it again.
    We just replaced drum and transfer belt on this machine before Christmas and a month later it's done it again. Anything we are missing you guys might know of? This Drum/Belt lasted 37k
    Sample customer sent is pretty bad. The color picture below is one of my saved samples from another machine.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1896
    I would guess the DV unit is the root cause of the issue. Check the spacer collars on the DV unit to make sure they aren't locked up. I'd think the DV is too close to the drum unit.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Ropariva
      • 693
      You sure a new tr belt was put in? It’s always been a compromised belt when we have seen that.
      • Dark Helmet
        • May 2009
        • 858
        I wasn't the guy who did it but the guy who did claims he put it in. He wrote it off on the call a month ago.
        Maybe he's mailing copier parts home to build his own machine
        • toddanderson
          • Dec 2005
          • 238
          you need a new transfer belt and drum
          • DavePo
            • Jul 2008
            • 305
            We had that issue and required all three Drum, Developer and Transfer Unit at same time. Seemed that if only one or two of the items where replaced the issue would return as it cascaded.
            • KYO_OEM
              • Aug 2011
              • 725
              take care for the moveable guide above the drum.
              Check small white gears for damage.
              We have good experience after we disassembled this guide in total.
              No jamming, running well and no more dots again.
              i attach KDC leaflet for further checking
                • 23010
                Nice documentation, thanks.
                • Dark Helmet
                  • May 2009
                  • 858
                  I wondered if that guide could damage the belt bet never assumed a high voltage leak!
                  We have teachers bend/break those things off. We just remove it and throw it in the bin as well. They run fine with out it.
                  Thanks for the guide.
                  • Dark Helmet
                    • May 2009
                    • 858
                    It doesn't quite line up with the star ring but the drum guide is slightly deformed and the belt has a hole blown thru it. The dot is a hole.
                    They took the guide off and hopefully that takes care of it.
                    • Tonerkiller
                      • Oct 2012
                      • 668
                      I have seen this also. My guess is there is some type of debris, getting behind the transfer belt and there is a short blowing through the belt. Other than that you need a new transfer belt , drum and clean everything up good.
