FS-C8025MFP Color offset in the longitudinal and transverse directions
  • pc-technik
    • May 2021
    • 4
    Hi,
    I have a FS-C8025MFP with Color offset in the longitudinal and transverse directions (see picture)
    Has anyone any suggestions on how to fix this?
  • KYO_OEM
    • Aug 2011
    • 709
    Wrong color registration after running the adjustment by the system menu:
    Run U468/ select “Initialize“ and press [OK] key
    Check if all values of [Auto] and [Manual] in U468 = ”0”
    If values = “0" enter U001 and press [OK] key / if other values > repeat U468
    No other changes, no copies/ no printouts during this procedure!!
    Finally run System menu > adjustment/maintenance >
    1. Calibration
    2. Color Registration
    In case of dirty Transfer Belt surface , check Transfer Belt cleaning motor drive at first
    Check eventlog for C7620, if yet new belt cleaning drive needed
    • Lunatech
      • Oct 2012
      • 199
      1. Calibration
      I believe in the Americas you would run U469/ select "initialize" and press [OK]. Is it different in Europe?
      • Ropariva
        • 650
        Also multiple manual runs of registration adjustment will eventually get it back to normal. You just need to see which way it has to go and input the maximum number/letter each time to move it slowly back to middle.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1868
          U468 will clear/reset the registration data
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • KYO_OEM
            • Aug 2011
            • 709
            Most problem we have had at Hanabi and Jupiter series was the broken gear from the transfer cleaning drive.
            Because of this the surface from the belt get dirty and no more registration adjustments are possible, at the end the data for correcting from the registration are higher then 255 and you has to reset the data by U468/ running calibration by system menue/adjustment_maintenance or U464/ regist and gamma to get new basic data less 255.
            At least fine tuning from registration by system menue and it`s finished.
            For checking if it`s coming from the dirty belt, take out eventlog and check for C76xx errors.
            It was a nightmare to get entrance to both screws from this fuc**** cleaning unit.
            If you are a lucky guy, only the driving shaft has popped out and you has to reattach it again to solve the problem without to disassemble everything dercibed in the attached bulletin from 2015.
            By the way, i have seen 1 older bulletin for newer systems (M8124cidn/Taskalfa 2460ci/ for maintenance, KDC added 2 holes in the inner cover to get easier access to the screws.
            • pc-technik
              • May 2021
              • 4
              Thanks a lot
              So i will have a look at the transfer cleaning drive an do the calibration
