Kyocera 3252 - Yellow Drum Not Spinning, No Yellow Print
not needed, entrance from the front.
Couplers are no component from main drive unit.
After you removed all 4 drums, dv units and transfer belt, you`ll see all 4 drum couplings.
Use grease for all 4 coupler and after reassemble from all parts, system will work.👍 2Comment
👍 2Comment
Credit goes to KYO_OEM. I literally took a screen shot of his photo and re-posted it.
This sort of issue is very old, ... all the way back to Falcon1, Falcon2, and Falcon3. Especially, immediately after changing a drum unit. The coupler seizes in one position, and cannot mate to the new drum unit. On the Falcon series, at a drum replacement I would put a couple drops of oil on the coupler and worked it in and out a few times to make sure it could move.
Congratulations on your success!!If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=👍 4Comment
blackcat4866
please don't remind me of the Falcon series
Lauch was in 2005 and I got a lot of gray hair from it.
The Hornet 3/ FS-9530DN, on the other hand, was a workhorse.
5 million pages were no problem with good maintenance👍 3Comment
