Kyocera 3252 - Yellow Drum Not Spinning, No Yellow Print
  • Peter Zeravla
    • Aug 2016
    • 34
    Hi, I removed the yellow drum from my Kyocera 3252 to check it, and after putting it back, it stopped spinning. The developer is working, and I can see toner building up only where they touch, but the printer is not printing any yellow at all. Any idea why this happens?
  • Ropariva
    • 676
    The drive dog at the rear is spring loaded and it has stuck in the disengaged position. You will need to free this up and likely replace the drum as it will have been damaged by the developer rotation. Make sure when you fit a new drum to rotate it until the drive engages. I’ve had this happen a few times so always take this precaution now.
    • ThisPete
      Too old to care
      • Jun 2014
      • 210
      Also, the little circlip that holds the drive cog in place fails, then when you pull the drum out the cog moves too far forward and it's drive pin falls out meaning no drive is transmitted to the drum, had it a few times. It's not obvious when looking in from the front unless you know to look for it.
      • Peter Zeravla
        • Aug 2016
        • 34
        Thanks for the suggestions. I checked the drive dog mechanism, and it seems fine. However, the drum is still not spinning. I even tried replacing it with another drum, and the same issue persists. It’s as if the machine isn’t sending the command to move the drum. Could this be a problem with the motor coupling, a sensor, or something related to the activation signal?"
        • KYO_OEM
          • Aug 2011
          • 719
          There is only 1 motor for driven all 3 colors drums.
          Each similar case in past would solved as Ropariva suggested. (in case that it happened like your describtion)
          If not, new main drive unit needed.
          Remove all 3 color drums, touch and turn the yellow drum coupling and compare with cyan and magenta.
          • Peter Zeravla
            • Aug 2016
            • 34
            In that case, I’m not sure what’s happening. The magenta drum is still working fine. First, the yellow drum stopped working. Then, after testing with the cyan drum, the same issue happened. Now, only magenta and black are working. Any idea what could be causing this?
            • KYO_OEM
              • Aug 2011
              • 719
              At first i would try to use a little bit grease on the couplings from all 4 drums.
              Now both couplings from ye + cy are not working probably.
              • Peter Zeravla
                • Aug 2016
                • 34
                It doesn’t look like a physical problem. I just pull out and then in. Is there anwy to say to the machine I have just installed a new drum?
                • Peter Zeravla
                  • Aug 2016
                  • 34
                  Doing test, I pull out the cyan drum and the pull in without touching it. It makes the noise when it is properly installed. It aligns it perfect as the other. But no yellow and no cyan printing.
                  • KYO_OEM
                    • Aug 2011
                    • 719
                    did you checked the springs for coupling?
                    We have had no magenta and no cyan after maintenance
                    This gallery has 1 photos.
                    • Lunatech
                      • Oct 2012
                      • 208
                      Right. The drive dog. He checked it already. Right?
                        • 23008
                        This is still the most likely cause.
                        • Lunatech
                          • Oct 2012
                          • 208
                          Agreed.
                          • Peter Zeravla
                            • Aug 2016
                            • 34
                            Where is that? Is it in the printer or in the drum? I've checked the drive dog from the drum. It seems to be fine. It works in another printer as well. I may not understand what that part is "springs for coupling" in this case. I'm not a native English speaker.
                              • 23008
                              In this photo:
