Latest version of Chrome - Can't access Web Browser
    • 16395
    #16
    Re: Latest version of Chrome - Can't access Web Browser
    Originally posted by Necrocannibal
    Is this done at the PC or on the machine? I don't have a lot of experience with this but been running into this lately.
    Sent from my SM-N986U using Tapatalk
    It's done from the PC via the Command Center.
    Go to Network Security>Network Security Settings. Enable TLS 1.2. Enable Sha 1 & Sha 2.
    • Necrocannibal
      • May 2008
      • 212
      #17
      What if you can't access the command center at all? I had a machine today that I couldn't access the command center with any browser, it kept saying unsupported protocol.
      Can it be done at the machine?
        • 16395
        #18
        I don't think you can change these settings from the control panel. What browser have you tried? You may need to download IE or Firefox. One of of 'em should work. It did for me.
        • tsbservice
          Field tech
          • 8019
          #19
          Try IE in compability mode.
          • Necrocannibal
            • May 2008
            • 212
            #20
            I tried Chrome, IE, Firefox and Opera. All gave the same message. I ended up setting up scans manually through the machine panel to get it working.
            • Necrocannibal
              • May 2008
              • 212
              #21
              Actual Internet Explorer or Edge?
              • tsbservice
                Field tech
                • 8019
                #22
                Internet Explorer
                • Necrocannibal
                  • May 2008
                  • 212
                  #23
                  Internet Explorer
                  Ok thanks.
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1887
                    #24
                    Today was the first day I've experienced this. I can confirm that the latest version of Safari won't load either.
                    I'm researching a way to temporarily disable these settings in Edge and Chrome, if needed. IE still works though.
                    After reading some threads, IE, Firefox or Chromium are the only possibilities to access these web pages until you can upgrade the machine or enable the TLS protocols to allow a connection.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • Necrocannibal
                      • May 2008
                      • 212
                      #25
                      I'm wondering if Kyocera will do a firmware upgrade to fix this? It's quote annoying.
                        • 16395
                        #26
                        The fix is already present in the machine. You just need to enable TLS 1.2/1.3 on all of your Kyocera machines.
                        • Necrocannibal
                          • May 2008
                          • 212
                          #27
                          Ok thanks, I'll try and enable those and see if it helps.
                          • tmaged
                            • Oct 2008
                            • 1887
                            #28
                            I've played around with it, but can't get it to connect in Chrome, Edge or Edge in IE mode. Even by allowing the IP address for an unsecure connection.
                            I would think there should be a place for intranet exceptions, but I can't find it.
                            Hope that helps !
                            -Tony
                            www.dtios.com
                            • Necrocannibal
                              • May 2008
                              • 212
                              #29
                              Interesting, there has to be a way to make it connect to it. I wonder if Kyocera is going to do anything about it?
                              • tmaged
                                • Oct 2008
                                • 1887
                                #30
                                They won't write new firmware for models that don't support TLS 1.2
                                Time to update the machines.
                                Hope that helps !
                                -Tony
                                www.dtios.com
