Kyocera M6535 Deletion from drum cylinder (Pic attached)
  • Doug James
    • Jan 2012
    • 935
    [CQ] Kyocera M6535 Deletion from drum cylinder (Pic attached)
    I am refurbing M6535 machines and it looks like the drum has a mark on it either from the charge roller or drum blade (sitting there for a long period). I tried to polish off with a dry towel and that had little to no success. Drum refresh seems to have a little effect after running several times. Anyone have any ideas how to solve this without buying new drums. You can see several deletions on my example. I circled one...Thanks for any help
  • Ropariva
    • 683
    Re: Kyocera M6535 Deletion from drum cylinder (Pic attached)
      • 23009
      You might try cleaning the drum surface with paraffin lamp oil, then rinse with alcohol.
      But honestly if there is something stuck to the drum surface, it means that the clearcoat is worn through, and it will stick again ... usually very soon. We had this experience with the black drum getting teardrop shaped ... "striction" I think slim calls it. The clearcoat wears out. The drum cleans, but it comes back.
      You might be surprised to hear this but these Mebius & MebiusII machines run best above 15K per month ... the more the better.
      • copykat93
        • Oct 2021
        • 281
        Try using water and a cotton cloth to clean the charge roller... maybe switch the charge rollers around to see what seems to make the most difference.
        • Doug James
          • Jan 2012
          • 935
          You can actually see the mark on the drum. The distance between the lines suggest the mark that is on the drum. The charge rollers arer new looking. I thought that was it at first myself. Thanks !!
          • Doug James
            • Jan 2012
            • 935
            Actually the machine it came out of had 6000 copies on it. Kinda thinkin the paraffin lamp oil might help. It's hard to get a pic of the mark. Very hard to see. Think it is more of a scuff on the coating. Never used paraffin oil. I heard you mention it several (being a Black Cat Groupie... lol) gonna give it a shot THANKS SO MUCH !!!!
            • Doug James
              • Jan 2012
              • 935
              For sure yellow is my saving grace... THANKS !!!! Appreciate Ya....
                • 23009
                Get as little as possible on the drum blade. Either clean the drum outside the unit, or clean/rinse/rotate 1/8 turn ... repeat x8.
                Paraffin lamp oil is a reasonable substitute for the best: Dispersant. I haven't seen Dispersant in many years.
                  • 16429
                  It was mentioned in this thread to swap the yellow drum but from my notes (from KYO) it says this:
                  Don`t touch the yellow drum marked with a yellow dot.
                  Don`t use it in other system on yellow position, if it would done in past you can get image quality problems because the yellow drum would used for internal system back up data.
                  We also have had a few cases with C9540 because all 4 drums would swapped mistakenly after cleaning.....
                  (yellow on BK position, magenta on cyan position and so on.)
                  If this kind of DK is broken, use new service DK unit with red mark.
                  I've never tried swapping it so I can't confirm but KYO has been pretty darn accurate.
                  • Doug James
                    • Jan 2012
                    • 935
                    It does sound like creating a problem you would chase for awhile... THANKS !!
                    • KYO_OEM
                      • Aug 2011
                      • 721
                      not for Mebius only....
                      Take a look for the drums from other systems, e.g. IrisI, II, 2020 high series (>32/35ppm)
                      What do you think, why do you find yellow dots on mounted yellow drums from factory but no dots on CMK?
