TA 3554ci blank screen
  • brancas
    • Jul 2009
    • 80
    Hi guys. I have 2 3554ci at different locations having the same blank screen issue. I had this problem before at different customers and the Main PWB or Control Panel usually solves it. However it's not working in these 2 machines.. When the machine is powered on the motors are running but no activity on the screen. New Main PWB and screen were installed. Any suggestions pls.
  • ntbann
    • Jan 2012
    • 628
    Maybe pull the fuser and fire it up to see if it will code out.
    • dalewb74
      • Feb 2018
      • 1153
      is it plugged directly into the wall? what other power-hungry equipment is in that room or nearby?
      • Lunatech
        • Oct 2012
        • 206
        At this point I would think it has to be cabling. It does seem when the 4 series first came out we were getting HDD errors and that turned out to be faulty SATA cables. I think the control panel has a SATA cable going to it. Maybe the same faulty batch? Long shot.
        For what it's worth.
        • PrintWhisperer
          • Feb 2018
          • 471
          Replace SSD and have firmware on thumb drive inserted on first power-up (important, only this way will cause SSD format to start).
          First boot – Watch for SSD format and Main firmware to load– Power off device
          Second boot – watch for full firmware to load.
          boot operations happen from SSD, “a machine without an SSD will not boot.”
          "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
          • KYO_OEM
            • Aug 2011
            • 714
            after power up and 5V operation panel power supply from main pwb present, the screen start it`s own "selftest".
            Same as engine pwb with motor turning and main with internal boot up routine.
            Power up >> 5V power supply for panel present >> "Welcome" message >> Kyocera or no/ other Brand logo >> communication with main pwb successfull >>"Programm Loading" message >> normal screen
            FYI: "Welcome" message is internal own operation panel component and independed to SSD panel firmware, part of internal operation panel BIOS.
            At first white screen and "Welcome" visible, after communication with main pwb/ ssd complete, screen must change to Logo and message "programm loading", finally to normal screen.
            You wrote "No activity on the screen" >> black blank screen or white blank screen?
            Black blank screen >> no 5V power supply for operation panel present >> no light/ no own boot up >> no message on the screen
            White blank screen >> faulty internal boot up from operation panel
            What happens with the operation panel led in lower right corner, red, blue, green, or flashing?
            Check related connectors all the way in.
            Main pwb YC14 << >> operation panel YC9
            SATA cable connectors on both pwbs/ change SATA cable.
            • brancas
              • Jul 2009
              • 80
              black screen. no lights on operation panel led. tried a working pwb from another machine same issue. however when the working pwb was re installed back into the machine that it came from same issue, black screen. i did notice that when the network cable was plugged into the previously working machine there was activity lights.
