M5526 lines on prints
  • Leebs14
    • Feb 2014
    • 457
    [CQ] M5526 lines on prints
  • dalewb74
    • Feb 2018
    • 1157
    Re: M5526 lines on prints
    so did you replace the ITB cleaning unit? did that fix it?
    • Ropariva
      • 680
      • Ropariva
        • 680
        • Leebs14
          • Feb 2014
          • 457
          • KYO_OEM
            • Aug 2011
            • 721
            Have had several reoccurence cases and prepared check point sheet for our techs.
            Maybe usefull for you also.
            • Ropariva
              • 680
              Nice one. In the worst cases it also takes out the K drum as the waste toner exits through that as well [emoji106]
              • what_moustache
                • Jan 2015
                • 15
                I've run into this on a few occasions (and we only have a few of these out in the field). Good to know I'm not the only one. I think if they had put the hook on the curved side of the 'D' on the waste toner gear, it wouldn't be nearly as much of an issue.
