Poor quality image in one side. Only in color. Black and white is fine.
  • Peter Zeravla
    • Aug 2016
    • 34
    Hello,
    I have trouble quality printing in a Kyocera TASKalfa 3051ci.
    One side of the printing is very clear or poor. The logo of the invoices is not printed because it is a light color. If I print a rectangle for each color it prints fine in the entire page. It is also fine if I print in black. I have tried the calibrate form the user menu. It didn't work. If I get into the maintenance menu, can I do a more efficient calibration or cleaning? What can I do?
    • 16557
    Re: Poor quality image in one side. Only in color. Black and white is fine.
    Originally posted by Peter Zeravla
    Hello,
    Can you show some examples? Are you using geniune OEM toner?
    • Rpizzle
      • Mar 2014
      • 47
      Not much to go on but could be polygon mirrors possibly. May just be staring to be dirty. This model is prone to this type of thing the rear edge will start to get light. not necessarily on every color at the same either.
      • dalewb74
        • Feb 2018
        • 1167
        what parts have been replaced?
          • 920
          Do sim 89 check all colors independently
            • 23010
            Try these images:
            • Peter Zeravla
              • Aug 2016
              • 34
              Sorry about answering so late. I lost the place where i had asked and i have realice now.
              • Peter Zeravla
                • Aug 2016
                • 34
                • Peter Zeravla
                  • Aug 2016
                  • 34
                  • Lunatech
                    • Oct 2012
                    • 218
                    I had a case some time ago similar to this. First side was fine, second side was almost entirely washed out. The difference for me was it was copies not prints. The white roller in the document processor was dirty and the CIS wouldn't calibrate properly.
                    • Tonerkiller
                      • Oct 2012
                      • 669
                      Maybe laser glass is dirty?
                      • Lunatech
                        • Oct 2012
                        • 218
                        Is it when copying or printing or both? If it is only while copying you are looking at something in the scanner. What to double sided scans look like on the monitor?
                        • Larhal
                          • 638
                          You Do realise that this post is 2 years old with a response from the originator?
                          Larhal
                          If all else fails read the Service Manual!
                          If that fails, meet me at the pub and we will discuss it.
                          • Lunatech
                            • Oct 2012
                            • 218
                            Well! I do now. I feel foolish.
                            • Larhal
                              • 638
                              We all do this some time in our posts.
                              Larhal
