TA 4002i has a continuously running exit unit until it goes into sleep mode
  • KCJeff
    • Apr 2022
    • 7
    [Misc] TA 4002i has a continuously running exit unit until it goes into sleep mode
    I had a customer just call about their TA 4002i's exit rollers running until the machine goes into sleep mode. Anyone have this issue? Since it's the end of my day I thought I would throw this out and check back in tomorrow before I have to call the dreaded Tech Support.
    Thanks for your help!
  • KYO_OEM
    • Aug 2011
    • 721
    Re: TA 4002i has a continuously running exit unit until it goes into sleep mode
    Set U346/ "Fuser Power Mode " to "OFF" or went into System Menue/ Adjustment_Maintenance/ activate "Silent Mode"
    Take care for attached addidtional informations
    • KCJeff
      • Apr 2022
      • 7
      Thanks for the info, will give it a try. I also changed the sleep and low power timers, they were set way to high.
      • Samanator
        • Sep 2017
        • 579
        Part of my set up for new and used machines is to set U346/ "Fuser Power Mode " to "OFF".
        I found out about setting U346 Fuser Power Mode on this forum about maybe 18 months ago and have implemented that change in all my xxx2s and xxx3s.
        To this date, I have a LOT fewer fuser failures than before.
        I also do it to the xxx4 series machines I get.
          • 16416
          That's good enough for me. Now it'll be part of my routine. Thanks.
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1888
            I've also started disabling IPV6 on all machines, since it's caused some Issues. I also turn all U287 to on.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • kuby
              • Oct 2007
              • 1409
              Yes Kyocera recommends disabling IPV6 also.
              • JR2ALTA
                • Feb 2010
                • 2033
                So what's the difference between "Fuser Power" and just plain "Silent Mode"? I've been using Silent Mode with good results, I never thought to look at Fuser Power.
                • tmaged
                  • Oct 2008
                  • 1888
                  We've tried silent mode, but it slows the machine down so much that customers complain. I believe it controls fans and other things also.
                  Fuser power just keeps the fuser from continually running.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  • Samanator
                    • Sep 2017
                    • 579
                    I understand turning off IPV6, I have been doing that from the time it has showed up on the machines.
                    What is the advantage of turning on all U287?
                    • tmaged
                      • Oct 2008
                      • 1888
                      All the C & CF codes, with the excpetion of the fuser related C6xxx codes, will try to reset themselves.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      • pascalb.
                        • Aug 2016
                        • 47
                        Hello,
                        just for info, I found the BT of the TA 4056i which corresponds to the 4002i at Kyo.
                        For noises at the ejection, I had often a few years ago
                        noise.pdf
                        Do not lament,
                        do not mock,
                        do not hate,
                        but understand.
                        • Paulm
                          • 69
                          Just put it in silent mode under maintenance and adjustments in system settings.
                          • darry1322
                            • Oct 2010
                            • 817
                            Thanks for posting but about half this thread is a discussion of Silent Mode. The first suggestion included Silent Mode.
