Kyocera taskalfa 5002 fuser tempeture
  • JINACHANDRANS
    • Sep 2019
    • 41
    Dear friends,
    kyocera mita taskalfa 5002i have fusing problem after unknown person attended the machine. i have doubt about the fuser temperature setting has changed. i don't have the service manual right now, please help me to solve the problem.
  • KYO_OEM
    • Aug 2011
    • 721
    Re: Kyocera taskalfa 5002 fuser tempeture
    Check media type weight settings at first.
    I don't think that some one changed the fusing temp by 1087
    e.g.
    Plain must be set to "Normal 2"
    • dalewb74
      • Feb 2018
      • 1155
      so would you care to share with us what the actual problem is??
        • 23009
        Another consideration is what media type is involved. All somebody has to do is load 290gsm media and leave it set to Plain, and you have a fusing problem. Definitely need more investigation here. =^..^=
        • JINACHANDRANS
          • Sep 2019
          • 41
          Thank you all guys for your replys. the problum was solved by changing the paper type to "TYPE 2" - "ROUGH".
            • 23009
            What was the problem again? I do not recall reading what the problem was. =^..^=
            • Samanator
              • Sep 2017
              • 579
              Kinda cryptic but someone must have put some heavy paper in a drawer expecting it to print just fine.
              If I only had a dollar for how many time that has happened to me.....
