Kyocera Mita FS-4100DN
  • AlexRust
    • Apr 2014
    • 41
    Kyocera Mita FS-4100DN. After replacing fuser everything seems to work but when you turn printer on it produces 2 loud clicks coming from the fuser area.
    What did I do wrong? Please help.
  • dalewb74
    • Feb 2018
    • 1125
    Re: Kyocera Mita FS-4100DN
    did you remove it and try to reinstall in case you missed something?
    • AlexRust
      • Apr 2014
      • 41
      Yes I did.
        Did you rotate the fuser by hand to see if you can hear the noise?
          • 8105
          Fit the old fuser back see if you still get the noise.
          • AlexRust
            • Apr 2014
            • 41
            Good tips. Thank you guys. Will try when I am visiting this site.
            • GIUBOSS
              • 1382
              Also be sure to check the gears in the transmission section
              • MAE
                • Jul 2023
                • 25
                Try to take out the fuser. Look on the right hand side. You should see a black plastic cam in the up position. Plug the printer in until it rotates downward. Then rip the plug out and reinstall.
