M6630cidn with color streaks
  • rickncs
    • Jan 2015
    • 11
    [CQ] M6630cidn with color streaks
    Hi All, long time tech/first time posting. Got a Kyocera M6630 color mfp with color streaks. Machine has 104k total and 82k color prints. Black drum was replaced in March for drum surface issues and is still good today. Couple weeks ago serviced it for color streaks on the right side. Could see the wear marks on three color drums matching the streaks, transfer unit was worn/dumping toner all over also. Three drums and transfer unit were replaced, all set up fine and worked good for a week but now the same issue has returned. I wouldn't think developer housings would cause this, have reached out to our Kyocera rep. for suggestions. This forum is way better source for good info so thought I'd give this a shot. Picture of sample is attached. TIA for any tips......REgarner color streaks.jpg
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Re: M6630cidn with color streaks
    Measuring the defect and checking it in the service manual against the repetitive defects guide should give you the answer.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • dalewb74
      • Feb 2018
      • 1160
      kyocera toner? kyocera parts?
      • rickncs
        • Jan 2015
        • 11
        Doesn't appear to be repetitive, more random. Will be going to site soon to take closer look. Thanks.
        • rickncs
          • Jan 2015
          • 11
          Absolutely. We're Kyocera dealer, machine on contract with all OEM parts and supplies. Didn't think to mention that in original post. Thanks.
          • Ropariva
            • 684
            • rickncs
              • Jan 2015
              • 11
              Returned today to check some other items- BTW I'm the only tech in our company in this territory. It's looking like one of 2 things so far. Either the client was referring to an old print from before and assumed it was still happening ( seen this a few times over the last 39 years ) or might have had something to do with a paper clip I found behind the mylar that runs along the bottom of the silver transport roller ( reg. roller? ) , on the same side as the defect, causing some weird electrical noise or interference? All belt samples and test prints looked fine so I'll monitor for a while and see. Thanks for the reply.
              • Ropariva
                • 684
                • rickncs
                  • Jan 2015
                  • 11
                  It's always something, that's for sure.
