KYOCERA M6026cdn SHIFTED COLOR / OUT REGISTRATION
  • luca72
    • Oct 2017
    • 1784
    Hi everyone, let me start by saying that we usually make Ricoh, but we also inherited some Kyocera, which I don't know fully, I have all the technical manuals of many Kyocera, I have access to the official Kyocera portal, but I had this problem.
    this m6026cdn needed the tk590 kit, but since it wasn't nearby, and I had many calls, we sent another company, and we supplied them with the kit, the problem was "toner fall around"
    their technician changed the kit, and now the machine, prints all the colors out of register, or color shift, as Kyocera says.
    I took it to the laboratory and checked a few things, I put the old kit back, and the problem remains the same.
    I found a bulletin (see attachment), and I followed the instructions, I updated the firmware, I did the calibration, and the color registration, but the problem is the same
    the colors are all shifted a lot
    I also tried removing the mobile protection of the ID sensors, because I suspected it wouldn't open, but nothing.
    Maybe I missed something on the bulletin?...I seem to understand, but I'm not sure, that there is a manual adjustment, but I can't understand it!
    Does anyone have any idea what the solution is?
    *my apologize, when i have do the attachment scans, i forgot to put color mode, but the problem is understandable anyway
    Thank you
    "I'll be back"
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: KYOCERA M6026cdn SHIFTED COLOR / OUT REGISTRATION
    Search on here, there are many threads on the subject. Generally you need to find which color could be causing the fault. Is the desnity good for each one individually ? There is firmware to reset the registration back to default, as the manual sometimes cannot get it back.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Ropariva
      • 680
        • 23009
        If I remember correctly, there is a firmware specifically written to correct the color registration issues. It does not install like normal firmware. There is a special procedure to install. I've only done it a couple times, and I don't remember the details. Maybe KYO_OEM has it.
        Note: Get yourself an ultraviolet flashlight for use, when doing color registration on all Kyoceras. It makes the yellow alignment marks visible as gray. This is the one I use:
        Amazon.com: COSMOING UV Flashlight, LED 395nm Ultraviolet Flashlight, Zoomable Pen Blacklight Flashlight IP54 Waterproof Detector for Pet Urine, Cat Dog Stains, Bed Bug, Household Wardrobe Toilet : Pet Supplies
        • luca72
          • Oct 2017
          • 1784
          hi, and thank you, I found the bulletin here on the forum, I updated the firmware to the version that should solve the problem, the colors have shifted by a lot, almost a centimeter
          "I'll be back"
          • luca72
            • Oct 2017
            • 1784
            thanks, I saw the procedure in the bulletin, but honestly I didn't understand it, I'll try to reread it
            "I'll be back"
            • luca72
              • Oct 2017
              • 1784
              hi, the strange thing is how could this happen just by replacing the consumables?...could there be some bulletin on the kyocera portal? here the registration is off by almost 1 cm
              "I'll be back"
              • luca72
                • Oct 2017
                • 1784
                I tried to check, but I can't understand the alignment procedure, the colors are shifted by about 5mm (see attachment)
                look the yellow, seem very out of much, I'm starting to think there's a bigger problem than the registration
                "I'll be back"
                • KYO_OEM
                  • Aug 2011
                  • 721
                  Special reset FW for reg.-data needed.
                  Available on kyo side
                  Take care for the bulletin.
                  • KYO_OEM
                    • Aug 2011
                    • 721
                      • 16416
                      It won't open for me.
                      • KYO_OEM
                        • Aug 2011
                        • 721
                        i tried before sharing and just now after download from this side.
                        Download/ open download folder/ rename from the file with .zip extention/ double click to open and it works.
                        @Billy
                        original zip version just send by email to you
                          • 16416
                          @Billy
                          Thanks, KYO.
                          • KYO_OEM
                            • Aug 2011
                            • 721
                            Here you get original zip file
                            • luca72
                              • Oct 2017
                              • 1784
                              thanks, but this is what I already have, the yellow and cyan colors, they are lower by almost a centimeter, I tried as suggested here in another thread to replace the HVU2 board, but it didn't solve the problem, now I'm trying to replace the complete laser box unit of yellow and magenta.
                              "I'll be back"
