Clearing the MK message on a Kyocera FSC8100
  • waynechurchill
    • 15
    I've just fitted maintenance kit A on a Kyocera FSC8100, but don't know how to clear the MK message on the control panel, can somebody please help!
  • HPLEXKYOPT
    • May 2009
    • 18
    Send the command from a DOS prompt through the LPT or re-route the LPT port through to the network port.
    Reset Fuser
    ECHO !R! LFRE "FUSR", 0; EXIT; >LPT1
    • collme
      Ricoh tech
      • 221
      assuming it has the up to date firmware so in maintainance you can go in and reset the 2nd transfere roller count as well. if all units are replaced, ie k dev 4x pcu's, itb unit and fuser, them counts will be reset. 2nd transfere need to be done in service mode after firmware upgrade and service file loaded onto a cf card to unlock maintenance mode
      • waynechurchill
        • 15
        Thanks for the replies, once i'd fitted the maitenance kit & checked the counts in the service mode which were all zero the mk message didn't go, but updating the firmware did remove the message.
        • NeoMatrix
          Senior Tech.
          • 3513
          HPLEX
          Is there a way to reverse the ECHO !R! LFRE....... to get the printer to output data back to the PC ? Just curious to know if there is a set of escape codes I can program in to make things easier. I can knock up a small app to read the data file for saving analysing ect....
          GDM
