Anyone had issues with 6002 model constantly grinding due to waste toner box backing?
  • Necrocannibal
    • May 2008
    • 212
    We have this one machine that we have probably put five of these in in the last 6 months or so. It will work for a while and then back up and grind again. We even replaced the waste toner assembly the waste toner bottle goes into with a new one. Not sure what is causing this but everything looks to be working fine and then a month or so later it starts grinding again.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 654
    Re: Anyone had issues with 6002 model constantly grinding due to waste toner box back
    Did you also replace the section in the main drive that houses the waste toner hopper? Or did you just replace the waste box unit on the lower left of the machine(would be the same as just replacing the waste bottle...)?
    • Necrocannibal
      • May 2008
      • 212
      Yes we replaced both units, the one on the side and the one in the back. The one in the back of the machine is the one that has been done multiple times.
      • ihatefinishers13
        • Feb 2020
        • 654
        Genuine toner? Also, how new are the DV units? We've had a couple issues with the waste section of the transfer unit not emptying correctly, and only one or two machines with the waste sections of the machine backing up.
        Sounds like a logic issue if it isn't emptying. What has Kyocera support suggested?
        • Necrocannibal
          • May 2008
          • 212
          I gave up talking with them about anything a long time ago. Developer possibly might be something to look into if it happens again, we use OEM toner.
          • ihatefinishers13
            • Feb 2020
            • 654
            Can't blame you there. One or two are good, the rest were useless.
            What about the main drive unit? I know you've replaced the hopper unit attached to the main drive, but that's what drives that unit to empty. Also, calibrating the color, including running the transfer unit replacement setting in U410/469/464 - I forget which one has it - resets the values of the transfer unit. The rest of the calibrations will hopefully help with the amount of toner being laid down. I assume you already did calibrations, but I always stick by the KISS method, as well as easiest/most logical things first.
            • Necrocannibal
              • May 2008
              • 212
              We swapped the whole unit the first time from a working machine because we didn't have the waste unit, it was the first time it happened. I am not sure on developer though so I am going to look into that, the machine is a 6002 so no color.
              • ihatefinishers13
                • Feb 2020
                • 654
                Sorry, meant calibrating the color as in the image, my bad.
                • Necrocannibal
                  • May 2008
                  • 212
                  No worries, I understand. I'll ask the techs if they have been doing that, even though I stress it to be done on every call already.
                  • tmaged
                    Owner/Service Manager
                    • 1865
                    The waste toner bottle unit, waste toner hopper unit (behind main drive), feed drive unit and Primary belt should all be done at once. I've tried doing fewer, but ended up going back and doing them all.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • KYO_OEM
                      • Aug 2011
                      • 707
                      from my experience the amount of stucking waste decreased dramatically after mounting from new waste box unit and usage from factory data instead of manual calibration.
                      Did techs followed bulletin M011_2V8_0053?
                      • JVergin
                        Service Tech / IT Rep
                        • 216
                        The feed drive unit drives the waste auger on the main drive unit. Since it's backed up so many times, maybe there's an issue with one of the gears in the feed drive assembly. missing teeth or a broken gear?
                        • Necrocannibal
                          • May 2008
                          • 212
                          I didn't know this bulletin existed, thanks.
                          • Necrocannibal
                            • May 2008
                            • 212
                            They all seemed fine, I think KYO found the answer with the bulletin.
                            • Stooey1871
                              • Aug 2022
                              • 17
                              I second that. Waste Bottle, Bottle holder, Waste hopper behind drive unit and feed drive unit. We have found old bottles wear out and creep forward enough to back up the waste. Make sure to feel test the vertical agitator in the black hose tube to the waste unit when re assembling new system also, to make sure its not seized up on install.
                              Not a great fan of this system, please bring back a simple waste bottle with full window and air bubble.
