7003i Line on page on long runs 20+ copies/prints
  • Samanator
    • Sep 2017
    • 579
    So any help would be greatly appreciated.
    • 16521
    Re: 7003i Line on page on long runs 20+ copies/prints
    I noticed that the black line moved over a couple of inches from the 1st page to the 2nd. I think we can rule out the DV unit.
    Laser?
    • Ropariva
      • 703
      • Ropariva
        • 703
        Kyocera 7002i thick solid black line
        Sent from my iPad using Tapatalk
        • Samanator
          • Sep 2017
          • 579
          Thanks Billy but the two pages are pages 7 and 11 from the Maintenance Report. For testing this problem, I would print out two Maintenance Reports in a row and use those 22 pages to test this problem. It only happens after printing or copying 20 pages or more in a run.
          Thank you Ropariva for the tip.
          • KYO_OEM
            • Aug 2011
            • 728
            have had good results with cleaning from drum drive shaft and usage from high conductive grease.
            Stripes are without rear and front margin, this means drum high voltage problem.
            If we get ground failure --> same result
            Clean drum driving shaft with alcohol and use high conductive grease (302LC94790 GREASE FLOIL G-347CA(10G) SP)
            Retigten the drum motor screws and try.
            Good luck
            • Larhal
              • 625
              Please disregard as my post was not relevant.
              Larhal
              If all else fails read the Service Manual!
              If that fails, meet me at the pub and we will discuss it.
                • 16521
                This seems to be a fairly common problem but I'm not sure if I've read a definitive solution. I'd try KYO's solution first as it's the easiest and it makes sense to me. Replacing the transfer belt and paper transport unit would be my next step if that doesn't work. Please let us know when you get it corrected.
                • subaro
                  • Oct 2010
                  • 1274
                  Laser?
                  How is the paper fed letter or Letter R . Would it then rule out the dev ?. Just curious .
                  • darry1322
                    • Oct 2010
                    • 817
                    We've been replacing transfer belts to resolve this. No idea why but that's what seems to be the best solution.
                    • 4Toon
                      • Mar 2023
                      • 112
                      Is there deletion on the edge of the document before scanning them in? If not and it is banding front to back w/o deletion and not lead edge to trail. It is that inconsistent I would replace the laser first. For board issues and HV issues they usually show up more consistently, but the laser can be very hit and miss with black banding on any models and brands.
                      Permanently banned from Konica SSD.
                        • 919
                        Make sure all the plastic c-clips are still on the end of the transfer belt roller .
                        • KYO_OEM
                          • Aug 2011
                          • 728
                          Have had same missing clip and system worked well after mounting from new one, but later we got same issue again....
                          Finally since drum driving shaft work, no more claims from endcustomer regarding black band...
                          • taskalfaman
                            • Nov 2009
                            • 137
                            check these two service tips in add.
                            this shoudl solve
                            Have fun
                            • Samanator
                              • Sep 2017
                              • 579
                              I meant to post this but I've been a bit busy.
                              First of all, thanks for all the help on this.
                              See attached picture.
                              I think this is it. Not sure, but duh...
