KM-8030 Streaks
  • stevee104
    • Mar 2007
    • 214
    KM-8030 Streaks
    I have two of these machines that streaks real bad first copy out then gets better the longer the run
    have update the firmware ,change paper with on luck.
    The problem is the fuser on both machines with copy count 180,000 and 239,000.I am getting ready to order a fuser because it is still under warranty but something tells me it not the fuser.
  • Absurd
    Just a brick in the wall
    • Oct 2007
    • 118
    I would take a look at the mc grid first. I have one machine that does this from time to time and that is what ive found to fix it consistently.
    Southern Duplicating of Mississippi
    PSN: DrAbsurd (if you know you know)
    "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
      • 23009
      There's a good chance that it is happening in the fuser. There is a firmware update to address this issue. There are three things to do.
      1) Upgrade firmware to v. 8-11-9 (this feature was added in v. 2-19-09)
      2) Set Sim 194
      Count to "90" (default 30)
      No. of Turns to "3" (default 1)
      Web will last the full PM cycle (500K)
      3) Replace fuser. If you don't mind doing the extra work it only really needs the heat roller, web, & cleaning roller.
      If your problem remains to can bump sim 194 to
      Count to "45"
      No. or Turns to "3"
      But the web will only last 1/2 the PM cycle (250K)
      • just a tech
        • Jan 2007
        • 332
        I've had main charge cause some streak issues on these models but most of the time it's been the fuser units due to buildup within unit on the rollers. Hardly ever have any buildup issues after updating firmware and completing the steps that blackcat has mentioned there.
        • Craigdumass
          • Jun 2009
          • 61
          Yes I have had the main charge create a shadow and you can increase the cleaning cycle I just replace the two wires, I have had more problems as BlackCat described and have been doing the same recomendation. The other problem that this new firmware repairs is when you have one of these in a lower volume place and the copies are light and I mean maybe half of the copy maybe light the new firmware increases the drive time speed on the developer roller to prevent this.
          • tech07
            • Aug 2008
            • 410
            8030 streaks
            Agreed... Fixed several recently....New firmware address both copy quality and fuser roller streaks...Don't forget to change U194 as stated above...If you don't, it won't fix the fuser streaks...
            • stevee104
              • Mar 2007
              • 214
              Okay guys change the fuser unit to this machine at 282,257 copies,did firmware upgrade and change
              everything in 194 to 90 and 3. Now 190,000 copies later i am having the same problem the upper roller is failing
              me. Is anyone else having this problem. We are using oem toner.
              • n25an
                • Jul 2008
                • 1030
                check to see if there are any marks on your fuser and then match them up to your line... also check to see if you have run out of web... the first means you have to replace fuser roller... the second means you need a new web... sometimes runnout of web causes this...
                Sad To Say I Don't Have a Life
                I do this stuff on the weekends too
                  • 23009
                  In the fuser kits there is now a note suggesting changing the count to "66". I had already set a few machines in the "60s" earlier the same week. =^..^=
                    • 30303
                    If its under warranty sent it back to china
