Kyocera 4035
  • Tonerhead
    Kyocera 4035
    I\'ve got a KM-4035 that slants the trail edge of 14 inch paper only. All other sizes are fine and the other three sides are fine. This happens thru the feeder, off the glass, or when printing an internal page such as in sim 402. Any ideas?
  • techman
    • Dec 2007
    • 49
    try coping legal from a diferent tray and see if the problem follows the tray
      • 23009
      I'll have to check if the 4035 has fuser alignment shims. The symptom you describe results from the fuser being out of alignment with the paper path. Many Kyoceras have a tapered shim to adjust the height of the front side of the fuser. There should also be a marker line on the frame to indicate the factory default setting of the shim. That's a good place to start. =^..^=
