I work with mainly ricoh, savin, etc and I\'m looking for the best high temp grease with out a stench.
fuser grease
Re:fuser grease
i use lubriplate from katun but i find i dont use fuser lube that much any more with the hightemp plastic parts. i do use it on the lower bushings in the smaller sharps. -
Re:fuser grease
Mita used to sell \"Temp-1\" grease that worked ok back in the day but for the past 6 or so years I have been using a product called \"Super Lube\", you can pick it up anywhere. Its a clear synthetic oil that comes in a pen type oiler. its rateed for about 400 degrees but I have never had a problem with it in fusers. It\'s a very thin oil so a drop is almost more then enough for any squeek.
I agree with Imagertech, I haven\'t needed to lube a fuser in a while. I feel that most copier an printer noises have nothing to do with a lack of lubrication. 97% of the time noise is caused by dirty bushings, shafts, clutches... A little cleaning or a new set of $10 bearings will last longer then a lot of oil.Comment
Re:fuser grease
You can also get superlube in a tube that is grease instead of an oil.Check with katun or Ames supply. Ricoh reccomends and sells mobil temp 78. thats the dark grey high temp grease. They also use barierta grease for the fuser bushings, but it ain\'t cheap and I\'ve only seen it from ricoh.:evil: :evil: :evil:Mystic Crystal RevelationsComment
Re:fuser grease
Which ever grease you use, make sure you slather it all over everything. Put on enough so that it can dry out in a month or so and turn into tar and cause all kinds of strange drive system drag problems. Unless you using something that comes in an aerosol can. If so, make sure you spray enough to coat the entire back of the machine and don\'t forget to hit all the clutches and the idlers in the exit area.
Any old tech can clean, but only a stud tech can transform a well running machine into job security with a can of WD-40.
Oh well, just my attempt at humor after a long Monday. :SComment
Molycote HP-500 Grease
Try Molycote HP-500 Grease. Its made by Dow Corning (sharp part # UKOG-0235FCZZ). The Sharp color machines are know for "click, click, clickclickclick, click..." whenever the fuser rotates. Smear this stuff on the ends of the driven fuser roller to stop the bearings from rocking back & forth.
Second choice (distant second) Chemplex High Temp Grease. It runs all over the place. It stinks, but doesn't burn.If you'd like a serious answer to your request:
i learned this from an old xerox guy, years ago. he had come out of retirement because he needed medical insurance. he started out working on the very first xerox copier. He told me that you can get all kinds of stuff to lubricate fusers, but the best thing is automatic transmission fluid. it's made to be a long lasting, high heat lubricant. put a little in an oil bottle and yer set. it's cheap, plentiful, and i used it for years. works great, especially on bearings...but remember, with lubricant, use only what you need, and put it only where you need itComment
Re: fuser grease
Ricoh fuser bearing come from the factory packed with a fluorinated grease called Barrierta. If you mix any other type of grease with fluorinated grease they nullify each others lubrication properties. DuPont Krytox grease is a fluorinated grease completely compatible with Barrierta with an even wider operating temperature range. Available from Image Supply Service. Image Supply Service
PhilComment
Re: fuser grease
MolyKote 300 is used for fuser gearing, actually listed as a part as well.
I'd call MolyKote and find some heat friendly spec-ed grease, help line lady is friendly.Idling colour developers are not healthy developers.Comment
Re: fuser grease
In 17 years I have never put grease on fuser gears so I have no use for it now either.Comment
IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ CertificationsComment
