I have a Panasonic FP-7722 and each time I print I get almost like a black smear on the bottom of every document. If anyone knows the main cause of this Please let me know or which part i need to clean to resolve this issue. Also what cleaning supplies I will need to do the job would also be very helpful.thanks in advance
Need Help Cleaning FP-7722
God ModeTags: adusting, cleaning, dev, dirty, exposure, fp7722, front cover, grey background, grid, jpg, lead edge, plates, pressure roller, shee
If the line isn't solid and appears interminently on the pages then clean the charge corona. Hope this helps. -
God Mode
God Mode
getting blank copys
after cleaning out the parts now im getting blank copys..seems like the ink doesnt want to feed into the drum.Comment
Are you sure you hooked in the charge corona properly? If that wire assym isn't plugged in properly it will effect your picture quality.Comment
I just had a machine do this problem to me last week. Ordered a drum, dcb, and corona unit. Installed them and it went away. With old machines like this you can never tell if the part itself is bad so just replacing them is best off.Comment
derek
ok take out the drum unit and look inside the machine you will see a slit glass which is just in front of the dev unit clean the slit glass with metho and the under side of the main glass with metho and all the mirros with metho and then the top of the glass with mr sheen or furniture polish see how that go'sComment
Start with a basic service 1st
optics ( dont 4get the 1's under the lens cover - 4 skrews)
remove glass dust shield (located above the drum behind main front cover)
try adusting the metal plates which r located above the scan lamp
make sure the morros are aligned correctly and not skewed
check F5-25 change to 0
adjust f6-11 exposure adustment
f6- 19 bias adjustment
if the dirty mark/line is lead edge try the following
r u finding toner on the transfer? if so check catch blade below drum blade
remove the dev unit - place dev unit over a sheet of paper and rotate dev roller by hand, check for deposits of toner on the paper, replace dev if it doesComment
