MP C6003 slow to print colour to finisher.
  • Lagonda
    • Aug 2008
    • 1649
    OK guys, here's another brain stretcher for you.
    We have a MP C6003 that works perfectly well until you ask it to print or copy in colour and deliver it to a finisher tray.
    Print or copy colour or B&W and deliver to the internal tray, no problem.
    Print or copy B&W and deliver to finisher tray, no problem.
    Print or copy colour and deliver to finisher tray, big problem!
    Will sit there and twiddle its thumbs for up to a minute before it starts to feed paper and it is around 1 min 10 sec from pressing go until the paper drops into the tray.
    Same goes for printer test pattern SP1103
    Swapped so far: IPU, sub IPU, BCU, Controller and HDD unplugged. No difference at all noticed.
    Where the hell do I start? and yes Frimwar is up to date.
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: MP C6003 slow to print colour to finisher.
    Stoopid question...
    How about the finisher frimwar?
    It's almost always overlooked, and I don't think it's even mentioned in the history.
    Even weirder...I've seen Java not being up to date, even if there are no apps that use it, cause issues by sticking its proverbial nose where it doesn't belong. Now THAT'S a long shot!
    • Lagonda
      • Aug 2008
      • 1649
      Originally posted by KenB
      Stoopid question...
      Yep finisher frimwar was definitely done and even another finisher was tried, still veeeery slow to put a colour copy into a finisher tray.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Wall voltage, perhaps?
        It could cause goofy logic problems.
        • Lagonda
          • Aug 2008
          • 1649
          Nope,did it at the customers as well as back here in my black hole of a workshop.
          Ricoh NTS have just got back to me and asked if I will do a full NVRAM reset. Knowing what a can of worms you can open I'm very reluctant, but if needs must.........
          • anothertech
            • 1771
            Have you tried the same thing on another MPC6003? maybe they all do it
            Maybe try down grading the firmware?
            Try new navram on controller and on bcu?
            • jonhiker
              • 661
              what is the driver you are using? what kind of document(s)?
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Please re-read the post.
                This happens on copies too, as well as internal prints.
                • Lagonda
                  • Aug 2008
                  • 1649
                  Cross checked against another 6003 at the customers and definitely a problem with just that copier.
                  Trying not to change nvrams and eproms but if I have too........
                    • 37532
                    Before clearing the NVRAM, backup the NVRAM up to a SD card. Check to see if you have the Birth Certificate for the machine. If not, print the SMC report or at least the Non Default data.
                    After clearing the NVRAM, see if the data backup to the SD card will reload correctly If it does, it makes life a lot easier.
                    • Lagonda
                      • Aug 2008
                      • 1649
                      Yep, gunna do all of that, and whats more I am going to do something that a lot of our field techs don't....read the manual first!
                      However all that will have to wait until tomorrow as I seem to be running the entire Service Department by my self as everyone else has buggered off to a meeting.
                      • copier tech
                        • 8172
                        The fact it prints/copies at normal speed to the finisher in mono but printing colour is the issue, maybe the machine running process control for some reason, maybe its printing colour from a different paper source ? machine is adjusting the fuser temp etc?
                        • TonerMunkeh
                          Professional Moron
                          • 3865
                          Which finisher is attached to the machine?
                          Hit it.
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            My thought too.
                            • HDSB
                              Field Tech
                              • Feb 2013
                              • 64
                              Firstly i would swap the fusers, i know you said its ok to the internal tray - does the machine sit on processing before the machine finally starts up?
                              next i would swap the finisher over, see if the fault is finisher or machine.
