SC530-18 Functional Problem MP9003
  • Toner Boy
    • Aug 2007
    • 357
    Issue with Tray 3 feed unit, just stalls every 10 pages or so. Swapped with tray 2 feed unit, and they both work (for now....).
    Tray 2 will also become useless until machine is rebooted, but only 3rd tray indicated 'out of service'.
    Anyone have a definitive code description for this? Only have -2 series and this subcode is nowhere to be found. Assuming feed unit motor, or connector issue.
  • Lagonda
    • Aug 2008
    • 1649
    Re: SC530-18 Functional Problem MP9003
    Looks like you may have to contact Ricoh over this one. My version of the Service Manual only goes as far as SC530-16 and I can't find a RTB referring to that SC either.
    SC530-01 to 16 refer to cooling fan problems so that may give you somewhere to start.
    • anothertech
      • 1762
      Paper feed unit fan 3 error
      After the fan turns on, the fan lock signal is checked at 1 sec. intervals.
      • Due to an obstruction or other problem, the lock signal went HIGH 1.5 s after the fan turned on and remained HIGH for 6 consecutive counts.
      • The lock signal should remain LOW during normal operation.
      • The fan stopped and then the machine stopped.
      • Fan motor overload due to an obstruction.
      • Fan motor connector, harness loose, broken, defective.
      • Fan motor defective.
      • Inspect the area around the fan for obstructions that could interfere with the rotation of the fan blades.
      • Inspect harness, connector and replace if damaged.
      • Replace PFU fan 3.
      • Toner Boy
        • Aug 2007
        • 357
        Nice - thank you guys. Machine only has 50K on it, so I'm expecting it was a connector issue and not defective fan.
        Will update if returns.
        • borisinho
          • Aug 2022
          • 2
          Hello, I have an MP 7503 machine with the code SC 530 19. There is no error code in the manual and it says that it is specified in a technical bulletin. Does anyone have that bulletin please?
          • Saturn
            • Nov 2023
            • 171
            It's Bulletin RD223042
            SC530-19 Paper feed unit fan 4 error
            Note: The machines of this series have four trays in Japan, and machines in areas outside Japan have three trays.
            Tray 1 is a tandem tray, but Tray 1 in Japan is smaller.
            - The lock signal should remain LOW during normal operation.
            - The fan stopped and then the machine stopped.
            - Fan motor overload due to an obstruction.
            - Fan motor connector, harness loose, broken, defective.
            - Fan motor defective.
            - Inspect the area around the fan for obstructions that could interfere with the rotation of the fan blades.
            - Inspect harness, connector and replace if damaged.
            - Replace PFU fan 4.
            I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
            • luca72
              • Oct 2017
              • 1748
              perhaps when you tear down the pick up station, you left a connector unplugged behind the vertical plastic cover, perhaps a tangle was hidden, and you didn't see it
              "I'll be back"
              • Gokhanuvez
                • May 2024
                • 2
                Hello everyone, I have a MP 7503 machine with the code
                SC 530 - 17 There is no error code in the manual and it says that it is specified in a technical bulletin. Does anyone have that bulletin please🙏🏻
                • luca72
                  • Oct 2017
                  • 1748
                  I checked, it's not actually in the manual (it stops at 530-16), however, it's probably some fan
                  check the pin 9 connector for all 3 fans was disconnected behind the waste toner bottle, and the front connector of the pick up stations behind the vertical plastic cover in front of the machine (x3 screw)
                  did you do any work before the code came out?
                  "I'll be back"
                  • semi
                    • Sep 2008
                    • 193
                    SC530-17 PFU fan 1 error
                    Paper feed unit 1 Fan error RTB No.: RD223042
                    • luca72
                      • Oct 2017
                      • 1748
                      great, now I found it too, to search on octopus RTB of the IM7000...you have to go to the MP6503 or previous models (there are quite a few)
                      compliments to ricoh..LOL
                      "I'll be back"
                      • Gokhanuvez
                        • May 2024
                        • 2
                        SC 530-17 / 18 The fan blade of the feed unit had come off its shaft. When I pressed it with my finger, it clicked into place and the device started working.
                        This gallery has 1 photos.
                        • luca72
                          • Oct 2017
                          • 1748
                          thanks for the feedback, everyone should do this.
                          "I'll be back"
