SC530-18 Functional Problem MP9003
  • Toner Boy
    • Aug 2007
    • 357
    Issue with Tray 3 feed unit, just stalls every 10 pages or so. Swapped with tray 2 feed unit, and they both work (for now....).
    Tray 2 will also become useless until machine is rebooted, but only 3rd tray indicated 'out of service'.
    Anyone have a definitive code description for this? Only have -2 series and this subcode is nowhere to be found. Assuming feed unit motor, or connector issue.
  • Lagonda
    • Aug 2008
    • 1649
    Re: SC530-18 Functional Problem MP9003
    Looks like you may have to contact Ricoh over this one. My version of the Service Manual only goes as far as SC530-16 and I can't find a RTB referring to that SC either.
    SC530-01 to 16 refer to cooling fan problems so that may give you somewhere to start.
    • anothertech
      • 1759
      Paper feed unit fan 3 error
      After the fan turns on, the fan lock signal is checked at 1 sec. intervals.
      • Due to an obstruction or other problem, the lock signal went HIGH 1.5 s after the fan turned on and remained HIGH for 6 consecutive counts.
      • The lock signal should remain LOW during normal operation.
      • The fan stopped and then the machine stopped.
      • Fan motor overload due to an obstruction.
      • Fan motor connector, harness loose, broken, defective.
      • Fan motor defective.
      • Inspect the area around the fan for obstructions that could interfere with the rotation of the fan blades.
      • Inspect harness, connector and replace if damaged.
      • Replace PFU fan 3.
      • Toner Boy
        • Aug 2007
        • 357
        Nice - thank you guys. Machine only has 50K on it, so I'm expecting it was a connector issue and not defective fan.
        Will update if returns.
        • borisinho
          • Aug 2022
          • 2
          Hello, I have an MP 7503 machine with the code SC 530 19. There is no error code in the manual and it says that it is specified in a technical bulletin. Does anyone have that bulletin please?
          • Saturn
            • Nov 2023
            • 171
            It's Bulletin RD223042
            SC530-19 Paper feed unit fan 4 error
            Note: The machines of this series have four trays in Japan, and machines in areas outside Japan have three trays.
            Tray 1 is a tandem tray, but Tray 1 in Japan is smaller.
            - The lock signal should remain LOW during normal operation.
            - The fan stopped and then the machine stopped.
            - Fan motor overload due to an obstruction.
            - Fan motor connector, harness loose, broken, defective.
            - Fan motor defective.
            - Inspect the area around the fan for obstructions that could interfere with the rotation of the fan blades.
            - Inspect harness, connector and replace if damaged.
            - Replace PFU fan 4.
            I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
            • luca72
              • Oct 2017
              • 1724
              perhaps when you tear down the pick up station, you left a connector unplugged behind the vertical plastic cover, perhaps a tangle was hidden, and you didn't see it
