03 Models SP Mode access changed from default
    • 8132
    Re: 03 Models SP Mode access changed from default
    Originally posted by kwehner
    I now have 2 machines that we bought from wholesalers that the previous dealer has changed the SP Mode access code, which makes it impossible for me to enter SP Mode. Does anyone know how to reset the SP Mode back to default? I have looked in the manual and searched copytech and the only answer seems to be replacing NVRAM. If you have info and don't want to post it please PM me.
    Just use the factory SP mode gives the same access as the standard SE mode.
    โ€‹
    • zed255
      How'd ya manage that?
      • 1024
      No sir, it actually does not. Some SP modes are not available in Factory SP that do appear in regular SP or Special SP. Conversely, there are SP modes only available in Factory SP mode. There is not a mode that gives access to all, so far as I'm aware. There are even settings that have to be made via telnet as there is no SP at all.
        • 8132
        Which settings are missing in factory SP?
        โ€‹
        • zed255
          • 1024
          #19
          Well, for one, SP5-081 which sets the SP access code for normal SP useage, and closely related to the subject of this thread. There are others but I have only bumped into those by happenstance, so I can't provide you a comprehensive list.
          In any event, in my humble opinion, no one should be encouraged to use Factory SP unless access to a particular function is required.
            • 37365
            #20
            There are a number of SP settings that I used to use that Ricoh has moved to Factory SP.
              • 8132
              #21
              Yes SP5-081 is not there but factory has all the main SP nodes you beed so if someone changed in the 806182 its no big deal.
              I have a few in public spaces & IT insist on locking down everything & changing all passwords etc understandably especially if they are charging for users or the public for prints/copies.
              โ€‹
              • fuwei2422
                • Nov 2014
                • 49
                #22
                I can help you fuwei2422@163.com
                • mrgene
                  • 53
                  #23
                  now im stupid how do you enter in to factory s.p.
                  • anothertech
                    • 1760
                    #24
                    I hope no one posts that here, maybe someone will pm you with it.
                      • 37365
                      #25
                      Same as always.
                      • mrgene
                        • 53
                        #26
                        same as always
                        you know i been a member on this site since 2009 I try not to bother people with stupid questions that are obvious for any ricoh tech, but it seems like you always get a smart ass response from someone why apparently is so much fricking smarter then everyone else.
                        • anothertech
                          • 1760
                          #27
                          I does seem like it's always the same, not from you, but just everyone posting and asking for service mode access and firmware. There is a reason that information is kept as quiet as possible. An untrained person could quickly ruin their machine by pressing the wrong buttons in service mode. Ricoh does not even put the service mode access codes in the service manual.
                          Please don't take it personnel, this is just not the place to get that type of information.
                            • 37365
                            #28
                            Not to mention the fact that Ricoh has already changed the Service Mode access code once because too many unauthorized people knew the old one. So far when they have changed it they have done so with new models only, though it would be possible to do so on older model simply with a firmware update.
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              #29
                              You can't change service mode login you can only change user tool admin login to bring back to default enter factory service mode sp 5846 46# clear then reboot
                              Regards Mark
                              • zed255
                                • 1024
                                #30
                                The newer SP mode access code CAN be changed.
