Mpc4502a With single pass feeder sc700-00
  • mrfuser
    • 1622
    Client got a small sticky stuck in the machine and they removed it before I got there. Unfortunatley it then started to go into an sc700-00 condition randomly. I went through the feeder and did not find anything else stuck in there. Pulled the covers and checked gears and they all look good. I ran a couple of hundred through it fine then two hours later they call back with the same problem. Any thoughts ?
  • copier tech
    • 8182
    Re: Mpc4502a With single pass feeder sc700-00
    I don't see a SC700-00 in the service manual. Are you sure it is SC700-'00'
    • mrwho
      Major Asshole!
      • 4299
      Indeed - SC700 start at 01 (both on the manual and on my-ricoh). If the machine is indeed giving out that error, then I'd start asking questions - where did the customer remove that sticky residue from, what kind of residue it was and, most importantly, if it's a foreign substance, billing the customer is probably not out of the question.
      Mascan42
      Ibid
      • GIUBOSS
        • 1436
        have you cleaned all the photosensors and around them? All the rollers?
        • mrfuser
          • 1622
          Sorry, typo it is 700-01. I went through and cleaned everything and am going back again today and will check again. I personally ran a couple of hundred pages and it worked perfect and as I said they called back a couple of hours later stating that code came back. Thank you all for any tips.
          • GIUBOSS
            • 1436
            try to unhook it from the machine and shake it upside down.
            • mrwho
              Major Asshole!
              • 4299
              This looks silly, but it's actually a good advise imho.
              Mascan42
              Ibid
              • mrfuser
                • 1622
                I went back today and ran over 900 pages through the feeder without a single problem so I guess whatever was in there worked its way out
                • tsbservice
                  Field tech
                  • 8028
                  Imho it may work and it may be terrible depending on Chaos theory. You know all that stuff laying inside will find new places hopefully outside DF but sometimes inside. That been said I also consider the idea, never thought of that
                  • mikadonovan
                    • May 2008
                    • 2931
                    That's easier said than done with the SPDF, but if you do, be prepared for the rain of paper clips and old staples.
                    NEVER ASSUME ANYTHING
                    • copier tech
                      • 8182
                      Now you can check/clean the correct sensor.
                      • Code: 700-01
                      • Description:Causes:Remedy:Bottom plate motor rotation: 1. Check or replace the bottom plate position sensor. 2. Check or replace the bottom plate HP sensor. No bottom plate motor rotation: 1. Replace the bottom plate motor. 2. Replace the ADF main control board.
                        • 37544
                        When you ran a couple of hundred pages were they 2 or 3 at a time or stacks of 10 or more. 2 or 3 at a time is the way to test a lift table problem.
                        • mrfuser
                          • 1622
                          Yes sir I tried every combination
                          I even slid the paper in and let it lift the tray and pulled her back out about 20 times
                          • skynetto
                            • Sep 2012
                            • 257
                            Sorry just ssen this now and maybe you have already solved it.
                            Check the B8021931 for cracks (Part nr.17)
                            Drive section 1 and ADF Parts
                            • mrfuser
                              • 1622
                              is this for a NON single pass or single pass feeder?
                              [ATTACH=CONFIG]46315[/ATTACH]
