IM C3500 ADF JAMMING
  • fritzyas
    • Jul 2011
    • 73
    We have issues on NEW 5 IMC3500 Machines.All are having ADF paper jam. No paper jams only when start copyin, the ADF feed unit will go down but the rollers will not turn. WE change already the motors and clutches and ADF control board but still the same. Need your help guys.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: IM C3500 ADF JAMMING
    Which DF is it and what jam number is it?
    Hit it.
    • fritzyas
      • Jul 2011
      • 73
      DF3110 ARDF - There was no code. Just when you press start, the pick up Roller will go down. The paper feed clutch and paper feed motor will turn on but it cant drive the paper pick up roller and belt.
      • TonerMunkeh
        Professional Moron
        • 3865
        That's bizarre. Were the ADF's fitted on the machines when you got them? Can you post a video of what they are doing?
        Hit it.
        • copier tech
          • 8170
          Check all the DF sensors work using input checks.
          Also check the DF drive using output check.
          Update the firmware may have a bug.
            • 16406
            There's probably a one way gear somewhere in the drive assembly that is bad.
            EDIT: I had the same exact problem on a Kyocera and it was a one way gear that was slipping. Not sure about yours. I had to remove the entire drive pack and disassemble to find the one-way gear.
            EDIT II: If you think about it, if this is a reversing ADF, it has one motor that is responsible for the forward direction of the paper (paper feed) and the reversing of the paper (duplex). So, it has to have a one-way gear so that the pick up and feed roller aren't turning when the paper reverses direction when duplexing. If the one-way gear is slipping you will lose drive.
              • 16406
              One more thing: The way I was able to determine that something was going on with the gear pack in the ADF is I ran a simulation to check the doc. feeder without paper and I put my finger on the pick up roller and noticed that it wanted to turn but the slightest amount of pressure from my finger would cause it to stop turning. From there I deduced that there had to be a one-way gear that was slipping. You may try that.
              • fritzyas
                • Jul 2011
                • 73
                Thanks Billy, You are right, when I remove the load on the drive gears they will turn but if i put just a small pressure it will stop. And I found out that their were 2 one way gear on that drive. I'll try to request for it and come back to you.
                • Morty
                  • Jan 2012
                  • 5
                  I had the same problem, I checked and cleaned a one-way pulley . The one that is engaged to the black gear. Below the pick-up clutch.
                  Good luck
                  Morty
                  • JonJames
                    • Feb 2014
                    • 19
                    have had issues with a few here
                    change these parts to fix
                    1 x D3FE4265 Paper Feed Drive Reversal
                    1 x D3FE4225 Gear, Timing Pulley Reverse Roller
                    1 x D3FE4281 Stopper, Paper Feed Reversal
                    Jon
                    • Gift
                      • Mar 2011
                      • 2459
                      Jon
                      Thanks, I haven't dealt with this issue so far but i put a note in our tech doc archive with your hint, sounds like we need get back to it some day^^
                      • luca72
                        • Oct 2017
                        • 1784
                        try to check the white plastic slider cover, of the rubber stamp position, under the trasparent upper tray in the under corner side (im sorry but i not able to post photos)
                        "I'll be back"
                        • bitels85
                          • Jun 2015
                          • 9
                          Did it work?
                          • bitels85
                            • Jun 2015
                            • 9
                            Same issue Model:IM C4500 df type: D3FE (DF3110) ARDF.
                            So far replaced:
                            AX200341 ELECTROMAGNET IC CLUTCH
                            D3FE5150 PCB1
                            ... and still jamming...
                            Has anyone resolved this?
                            To be honest I don't understand
                            • semi
                              • Sep 2008
                              • 195
                              Change the one way bearing on the sep roller drive shaft
