optics cleaning cloth + platen glass slippery product
  • Gift
    • Mar 2011
    • 2459
    #16
    Re: optics cleaning cloth + platen glass slippery product
    Originally posted by mikadonovan
    I don't use this much anymore. Newer CIS DF's don't need it.
    Blast from the past
    • luca72
      • Oct 2017
      • 1780
      #17
      Originally posted by Mark Bbb
      I try to work (and live) ecological, that implies that garbage (plastic) needs to be avoided.
      That's why i want to make my own glass cleaner...
      you can try "white vinegar", it's cheap, it's good for everything, and it's as ecological as you want, only it smells a bit, I don't know if the customers would like it? I also use it when I wash the moka kettle for coffee, I leave some on the bottom for an hour and then I throw it, and I rinse everything with running water
      "I'll be back"
        white vinegar is great for cleaning windows .. shower stalls ..coffee pots. Been using it for decades for those purposes. I also use in to pickle cucumbers.
        after a while I don't really notice the smell.
        • Klydon
          • Mar 2009
          • 243
          #19
          Chiopee ? you mean the yellow stretch clothes? they have a small amount of oil on the to attract toner.
          use a soft lint free cloth to clean optics
          try RainX on platen glass.
          slippery? are you sure the static eliminators are working not damaged?
          Big +1 on the Rainx. That is my go to these days and I still use it from time to time, but mainly as a anti-static measure in paper paths, which it does a decent job at.
          I also used Brillanize back in the day when DF belts were a thing to move paper across the exposure glass. That stuff worked great.
          • ZOOTECH
            Senior member of CRS
            • 3375
            #20
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              #21
              • copier tech
                • 8145
                #22
                Hoi,
                i used the Photex optics cleaning cloth, but i can't find it anymore.
                Now I use Chicopee, and i'm not satisfied.
                Which optics cleaning cloth do you use?
                AND
                How to make a platen glass more slippery?
                Thank you again for your input!
                We use Wypall good strong for optics & general cleaning.
                WypAll(R) X70 Cloths - Folded / White-Kimberly-Clark Professional*
                & I use car screen wash on mirrors works a treat & a 5tl bottle lasts for years!
                  • 23008
                  #23
                  Same here ... I just call it washer solvent. The formula that I've come up with is:
                  2 gal -10F washer solvent
                  3 qts vinegar scented Windex
                  1 qt Cleaning Vinegar
                  Here in Michigan, it's important that your glass cleaner isn't frozen solid when you show up to your first call. =^..^=
                  • anothertech
                    • 1770
                    #24
                    Yes, I'm in New York. I add a little isopropyl alcohol to my window cleaner during the winter.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      #25
                      In the absence of the Photex cleaning cloth, i used a microfiber cloth for test.
                      After this rather wet cleaning i used the Chicopee towel to rub dry (and take away ozone remainder)
                      I'm very satisfied of this result.
                      Never before I had a mirror so clean; the reflected light is really powerful!
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        #26
                        To ameliorate the sliding of the original on the platen glass I have put some oil on it and spread it with a cloth ...
                        works fine, but I hope the oil-smell will disappear soon.
                        I have putted to much vinegar in my selfmade glass cleaner, so taking away the sliding characteristic...
                        • Vincent128
                          • Sep 2015
                          • 349
                          #27
                          Brillianize and a lint free paper towel or microfiber - use it for all sorts of things.
                          Good stuff
                          • mloudy
                            • Oct 2015
                            • 784
                            #28
                            Sontara AC1213 White 12" x 12" Aerospace Grade Wipes
                              • 37494
                              #29
                              Next time use silicon fusing unit oil.
                              • DRichard
                                • May 2008
                                • 482
                                #30
                                Use olive oil and red-wine vinegar...add salt and pepper for a light lunch condiment!
                                "Enjoy every sandwich."
                                -- Warren Zevon
