MP C 6003 J019 jams
  • jrob416
    • May 2011
    • 112
    MP C 6003 J019 jams
    I have been dealing with an MP C6003 with a constant J019 jam. Leading edge comes to the fuser, but stops there. I have changed fuser and entire 2nd transfer unit with no luck. I have checked sensors and motors in the area with the input/output function and all seems well. I am at a loss and would appreciate any input that is offered. Thank you.
  • GIUBOSS
    • 1437
    Re: MP C 6003 J019 jams
    check if the image is correctly imprinted on the transfer which may not move well, try all the paper trays and the bypass. Does the fuser unit rotate with certainty well?
    • COPIERMAN
      • Jun 2009
      • 559
      manually select paper tray and see if it feeds properly. May sure that right paper settings are showing on display. it scans and think it is a certain size and paper feeds an is different will stop causing jam.
      • luca72
        • Oct 2017
        • 1792
        hi, try to check on the machine the "drive unit: fusing / exit
        maybe there is some problem with some problem on a motor or some one-way bearing, try one from another machine
        p.s. I don't know if the code is exactly that of the attachment, look for the correct one for the mpc6003
        "I'll be back"
