I have been dealing with an MP C6003 with a constant J019 jam. Leading edge comes to the fuser, but stops there. I have changed fuser and entire 2nd transfer unit with no luck. I have checked sensors and motors in the area with the input/output function and all seems well. I am at a loss and would appreciate any input that is offered. Thank you.
MP C 6003 J019 jams
Re: MP C 6003 J019 jams
I have been dealing with an MP C6003 with a constant J019 jam. Leading edge comes to the fuser, but stops there. I have changed fuser and entire 2nd transfer unit with no luck. I have checked sensors and motors in the area with the input/output function and all seems well. I am at a loss and would appreciate any input that is offered. Thank you. -
maybe there is some problem with some problem on a motor or some one-way bearing, try one from another machine
p.s. I don't know if the code is exactly that of the attachment, look for the correct one for the mpc6003Attached Files"I'll be back"Comment
