MP C307 SC121
  • hanspeter75
    • Mar 2010
    • 37
    MP C307 SC121
    Hello together
    Have the problem with this SC code. The error always comes when starting the device. Scanner does not initialize and the lamp does not turn on. Motor / scanner completely and the sensor changed....no success. Any idea where the problem is before I change the BICU and Contoller? (I know the problem with the clamp of the scanner)?
  • GIUBOSS
    • 1385
    Re: MP C307 SC121
    check the movement of the trolley which has no friction, as per the service manual, all that remains is to replace the ipu or bcu
    • MIKON
      • Jul 2015
      • 186
      Re: MP C307 SC121
      Check the scanner motor cushion (mount).
      • Polarbear
        • Feb 2012
        • 1070
        Re: MP C307 SC121
        At this point, I would look at the BICU, as it controls all the workings in the machine. The controller is mainly and interface between the device and the outside world - almost like a computer. That is why in a lot of cases it has its own hard disk drive.
        Press the GREEN button!!
          • 8120
          Re: MP C307 SC121
          Originally posted by hanspeter75
          Hello together
          Before replacing any parts its always worth updating the firmware, try the latest package.
          • luca72
            • Oct 2017
            • 1710
            Re: MP C307 SC121
            Hello together
            it could be some output from the psu...
            • hanspeter75
              • Mar 2010
              • 37
              Re: MP C307 SC121
              bicu was faulty
              • Bourriks
                • May 2016
                • 38
                Re: MP C307 SC121
                Yup, firmware upgrade, and check the BICU if the update does not resolve.
                • davel
                  • Oct 2011
                  • 1089
                  Re: MP C307 SC121
                  He already fixed it almost 2 years ago, read the entire thread.
                  • Bourriks
                    • May 2016
                    • 38
                    Re: MP C307 SC121
                    I was reading topic because I had the same issue, but in my case it was the lamp trolley who was stuck and I had a bad white reference reading when stating the copier.
