Mpc 4504
  • tavorh
    • Sep 2016
    • 25
    Mpc 4504
    Hello!
    I have a problem with mpc4504, when I try to copy or print the device just report printing:1min and the job is not realized.
    Anybody have any suggestion?
  • GIUBOSS
    • 1435
    Re: Mpc 4504
    Originally posted by tavorh
    Hello!
    more info please ..., it could be a software, hd or firmware problem. PM counters?
    • csliao
      • Oct 2021
      • 33
      Re: Mpc 4504
      [QUOTE=tavorh;1967645]你好!
      我的mpc4504有問題,當我嘗試複製或打印設備時,只報告打印:1分鐘,但沒有實現作業。
      有人有什麼建議嗎?[/引用]
      HDD error,change HDD
      • mikadonovan
        • May 2008
        • 2931
        Re: Mpc 4504
        Make sure that the machine is not installed as a WSD.
        NEVER ASSUME ANYTHING
        • luca72
          • Oct 2017
          • 1778
          Re: Mpc 4504
          [QUOTE=csliao;1967904]
          你好!
          有人有什麼建議嗎?[/引用]
          I also think it may be the hdd, to be formatted / replaced
          "I'll be back"
          • guitar9199
            • Sep 2016
            • 1100
            Re: Mpc 4504
            Check your printer driver. Make sure you're using the PCL driver (Windows). If you have a Mac/Linux PC, be sure the machine has PostScript installed, otherwise you won't be able to print. Start with the easy stuff.
              • 8144
              Re: Mpc 4504
              That won't affect copying.
              Power down the machine, unplug the HDD & try a copy/print again.
              • mikadonovan
                • May 2008
                • 2931
                Re: Mpc 4504
                That is true, but he indicates a printing error, as the machine says "copying" when copying.
                • anothertech
                  • 1769
                  Re: Mpc 4504
                  The first post says "when I try to copy or print"
                  • Big Durbs
                    • Sep 2012
                    • 16
                    Re: Mpc 4504
                    Classic HDD fail , replace HDD and your all good
