SC670-03 on MPC5503A
  • Popolopo
    • May 2023
    • 102
    [Error Code] SC670-03 on MPC5503A
    Hi. I got one machine having SC670-03. Based on manual, I swap PSU, BCU, IPU, 2 IOB, and flat cable from good working machine. But the code still there. I even try swap controller, but it still giving SC670-03.
    Any help?
    • 8100
    Fit all the original boards back. Remove all the toners then power the device back on.
    If the device doesn't error, clean all the toner chip contacts then install each one at at a time, closing the door inbetween.
      • 36796
      I do not find SC670-03 listed in my copy of the Service Manual, only SC670-00, Communication Error at start up. Usually caused by the USB cable to the display. Enough of a problem that Ricoh-USA put out a bulletin on it.
      • anothertech
        • 1756
        This something I found in Goose Guide, Check for Missing 5V on IPU CN576 Pin 1 and PSU CN911 Pin 7
        Also there are quite a few things in firmware to help with sc670-03, update firmware if you can.
        • Popolopo
          • May 2023
          • 102
          Already try it. It stuck at blue screen at when starting and go SC670-03.
          • Popolopo
            • May 2023
            • 102
            Got bulletin for it. Older firmware indicates SC670 but newer one will have specific SC code either SC665 or SC664.
            • Popolopo
              • May 2023
              • 102
              Got 5V when check those pins. Can't update as it will straight SC670-03 when boot up. Try insert SD Card for update, it does nothing.
                • 36796
                Try powering up with a jam door open. That prevents the engine from starting which if the SC is engine related prevents the SC and allows you to get into SP mode and might also allow SD card firmware update /reload.
                • luca72
                  • Oct 2017
                  • 1677
                  Any help?
                  ok, let's start with the cheapest solutions, after what slim slob suggested, I would try to replace the nv-ram, if you buy them on e-bay, or ali-express, you can find them for a few euros, and I discovered that they break much more easily than you think, you can also take them from another machine if you have one.
                  • Popolopo
                    • May 2023
                    • 102
                    If I open duplex and front cover, it will stay at blue screen and SC670-03. But if I unplug duplex cable, I able to update the firmware using SD Card. I suspect duplex unit was the problem and try to swap it with another machine. Still 670-03 when swap and reconnect duplex.
                    • Popolopo
                      • May 2023
                      • 102
                      Already try that when swap other controller.
                      • luca72
                        • Oct 2017
                        • 1677
                        I didn't read it well, but I remembered that in the past it had happened to me that it was one of the toner cartridges, as copier-tech said
                        • MIGUELMARCHENA
                          • Feb 2018
                          • 179
                          Hello, good day.
                          Can you please give me the AliExpress or eBay link to get the NVRAM?
                          Thank you very much.
                          • luca72
                            • Oct 2017
                            • 1677
                            Originally posted by MIGUELMARCHENA
                            Hello, good day.
                            hi, try this:
                            https://it.aliexpress.com/w/wholesal...tems_or_groupL ist.search.0
                            should be the FM25V20 on the metis
                            I usually buy a new one, even in ricoh, and then I create a .bin file with which I can rewrite the ones recovered or used on other machines of same model, using a Chinese eprom programmer Xgecu pro T48 and its free software
                            but pay attention first to buy, first remove the white little sticker on original nv-ram, and check the exact version of component, could be that change the memory capacity from a model machine and one other
                            • MIGUELMARCHENA
                              • Feb 2018
                              • 179
                              hi, try this:
                              Hello Luka, good morning.
                              Thank you very much. I'll do so.
                              Best regards.
