MP C6004 Scanning with blue haze
  • digicor
    • Jul 2008
    • 1153
    i have a MP C6004 thats scanning and copying with a blue haze all over it, not sure why, it was scanning clean for the last 2 months after installed... iis there a setting to reduce this in the doc feeder?the scanner glass is clean. the optics have been cleaned....any suggestions will be appreciated
  • Mako
    • Jan 2025
    • 654
    Take the glass out and shine a flashlight off of the glass at a shallow angle do the same to the mirrors. I have seen a haze buildup on the optics where they look clean until you do this test.
    • digicor
      • Jul 2008
      • 1153
      here is samples
      • digicor
        • Jul 2008
        • 1153
        any other ideas?
        • sandmanmac
          • 3979
          The only few times I've experienced a similar symptom is after someone has done an engine clear on the machine.
          It was recovered by re-entering the non-defaults from the factory birth certificate - most specifically the Grey balance settings
          • digicor
            • Jul 2008
            • 1153
            grey balance setting in the scanner service mode? or where? sorry to ask, im not Infront of a machine at the moment
            • digicor
              • Jul 2008
              • 1153
              found it thank you
              • digicor
                • Jul 2008
                • 1153
                any other ideas?
                • digicor
                  • Jul 2008
                  • 1153
                  im changing the doc feeder, and or the optics tomorrow, nothing worked, except in copy mode i lightened up the density all the way and the blue shading went away
                  but, in scan mode, the blue shading is still there no matter what we did.
                  i checked and re adjusted 4-609-002,4-610-002,4-611=002 to no avail no matter what we put the setting on, extremes, no difference, i lifted up on the doc feeder as it fed difference,
                  • luca72
                    • Oct 2017
                    • 1750
                    have you tried to run sp801 (reset scanner application)? ..maybe the customer played with the numerous scanner settings(?)
                    it happened to me a couple of years ago on a mpc2051, I lost at least half an hour to find the combination of settings in the scanner menu, in the photos of the identity cards they all looked African pixeled
                    "I'll be back"
                    • digicor
                      • Jul 2008
                      • 1153
                      where 801? sp4?
                      • digicor
                        • Jul 2008
                        • 1153
                        I dont have a 4-801 on mp c6004
                          • 37397
                          where 801? sp4?
                          I think it might be SP 5801 unless he is referring to Scanner SP.
                          • digicor
                            • Jul 2008
                            • 1153
                            5801 is memory all clear... we don't mess with that...
                            is there a scanner all clear?
                            • dalewb74
                              • Feb 2018
                              • 1135
                              have you changed anything under the scan resolution settings? i agree with everyone else about the cleaning. i have had times that i cleaned and thought i had done a good job cleaning. only to discover there was a bit more. not saying you didn't.
