MP C6004 Scanning with blue haze
  • digicor
    • 1150
    i have a MP C6004 thats scanning and copying with a blue haze all over it, not sure why, it was scanning clean for the last 2 months after installed... iis there a setting to reduce this in the doc feeder?the scanner glass is clean. the optics have been cleaned....any suggestions will be appreciated
  • Mako
    • Jan 2025
    • 252
    Take the glass out and shine a flashlight off of the glass at a shallow angle do the same to the mirrors. I have seen a haze buildup on the optics where they look clean until you do this test.
    • digicor
      • 1150
      here is samples
      • digicor
        • 1150
        any other ideas?
        • sandmanmac
          • 3969
          The only few times I've experienced a similar symptom is after someone has done an engine clear on the machine.
          It was recovered by re-entering the non-defaults from the factory birth certificate - most specifically the Grey balance settings
          • digicor
            • 1150
            grey balance setting in the scanner service mode? or where? sorry to ask, im not Infront of a machine at the moment
            • digicor
              • 1150
              found it thank you
              • digicor
                • 1150
                any other ideas?
                • digicor
                  • 1150
                  im changing the doc feeder, and or the optics tomorrow, nothing worked, except in copy mode i lightened up the density all the way and the blue shading went away
                  but, in scan mode, the blue shading is still there no matter what we did.
                  i checked and re adjusted 4-609-002,4-610-002,4-611=002 to no avail no matter what we put the setting on, extremes, no difference, i lifted up on the doc feeder as it fed difference,
                  • luca72
                    • Oct 2017
                    • 1676
                    have you tried to run sp801 (reset scanner application)? ..maybe the customer played with the numerous scanner settings(?)
                    it happened to me a couple of years ago on a mpc2051, I lost at least half an hour to find the combination of settings in the scanner menu, in the photos of the identity cards they all looked African pixeled
                    • digicor
                      • 1150
                      where 801? sp4?
                      • digicor
                        • 1150
                        I dont have a 4-801 on mp c6004
                          • 36746
                          where 801? sp4?
                          I think it might be SP 5801 unless he is referring to Scanner SP.
                          • digicor
                            • 1150
                            5801 is memory all clear... we don't mess with that...
                            is there a scanner all clear?
                            • dalewb74
                              • Feb 2018
                              • 1110
                              have you changed anything under the scan resolution settings? i agree with everyone else about the cleaning. i have had times that i cleaned and thought i had done a good job cleaning. only to discover there was a bit more. not saying you didn't.
