Some Ricoh printers not updating Firmware
  • Jinn
    • May 2023
    • 134
    Hi Ricoh Experts,
    Some ricoh models firmware is not updating. I have tried using SD and through ricoh online firmware update tool. Both methods give error. Online tool gives error "Device is disconnected or OFF" when its already connected, pinging and showing on WIM.
    SD Firmware update gives error E61.
    Models are C4503 and C305.
    Is there any solution to update the firmware.
    Thanks in advance
  • luca72
    • Oct 2017
    • 1781
    Originally posted by Jinn
    Hi Ricoh Experts,
    Thanks in advance
    I have a couple of 3004s lying around that won't read the sd card from slot 2, we updated them with RFU, it's probably a controller failure, but everything else was working fine, so we left them as is
    as for RFU, make sure FTP is enabled in WIM, and also SSDP, after the update you can turn them off
    "I'll be back"
    • Jinn
      • May 2023
      • 134
      Thankyou for your response.
      Can you please guide how to do this RFU firmware upgradation?
      • luca72
        • Oct 2017
        • 1781
        RFU its abbreviation of "Ricoh Fimrware Update tools", its same thing of that you said of used, probably RFU does not detect the machine on the network because FTP is turned off (maybe), or the machine has a different admin login password than the default one in RFU, e.g. admin without password vs admin - admin, or Admin vs Admin
        check if the lan parameter of the machine are correct, in particular also the subnet mask
        "I'll be back"
        • anothertech
          • 1771
          RFU is not Firmware update tool. RFU is Remote Firmware update, to be used with web Image monitor.
          • sandmanmac
            • 3981
            Hi Ricoh Experts,
            Thanks in advance
            Have you tried a different SD card?
            Make sure it is properly formatted.
            I also believe the capacity has to be less than 1Gb.
            Are you using the Package Firmware or .fwu (romdata) files?
            Whatever you are using, try the other way.
            The firmware update tool or package firmware will also not work if there is ANY custom firmware modules installed. I've run into this issue before. and had to install a regular version of the firmware via an SD card using the .fwu files, and then it would update using the tool
            • luca72
              • Oct 2017
              • 1781
              sorry, I meant RFUT, from RFUT.exe
              "I'll be back"
              • Jinn
                • May 2023
                • 134
                I am using "package" firmware. The capacity of SD card is 512 MB. It works fine on other machines. I f I copy another firmware of different model in the same SD card it updates the firmware but this one give error E61.
                Ricoh online firmware tool also give connection /device off error while its pinging printing perfectly.
                I do not have .fwu (Rom data files)
                  • 8164
                  The fix is to first update the system / copy first then you can update using the .pkg file.
                  Use WinRarr to open the .pkg file, inside are all the .fwu files, copy these to a folder & name it romdata
                  But as you know the C305 doesn't use the package firmware, it can take a few attempts before it will start updating.
                  www.printerfirmware.co.uk
                  • Jinn
                    • May 2023
                    • 134
                    The same procedure is applicable to C4503? I have extracted the files. Now will create a folder in the SD card as you mentioned. Hopefully it will take the firmware?
                    It will ask for the manual selection of the firmware like system, controller, printer, scanner etc or it will run as normal?
                      • 8164
                      Yes, any device that uses package firmware the process is the same.
                      • dalewb74
                        • Feb 2018
                        • 1153
                        i don't know if this applies in your case. i was trying to update ricoh firmware the other day. and was getting the error E61. and i did a bit of inspecting, i found out the firmware was already at the most updated version.
                        • CopyBats
                          • Aug 2011
                          • 147
                          Login to the physical machine as admin.
                          User tools , system settings, look for security settings and see that firmware update is not disabled.
                          If it works, don't touch it.
                          • Jinn
                            • May 2023
                            • 134
                            Thank you so much. I appreciate that. It really helped me and worked like a charm. C4503 firmware is updated by extracting the files and copy them to the SD card.
                            Now the problem is c305 firmware is also not upgrading using the RFUT online. I do not have the firmware of c305 to extract.
                            It would be great if you please share the latest firmware ? PM please
                            Thanking you so much
                            Regards,
                            • Jinn
                              • May 2023
                              • 134
                              I was checking these options in C305 but they are not showing in this model. I could not find the option "Firmware Update"
                              +SSDP is ON
                              +​​​​​FTP is ON
                              Firmware is not upgrading online
