MPC3504ex missing PDF and PS printer language
  • Popolopo
    • May 2023
    • 143
    [Misc] MPC3504ex missing PDF and PS printer language
    I got a 2nd hand MPC3504ex, currently missing PDF and PS printer language. Usually I just use SD Card, put romdata and install it. Unfortunely, this time, it doesnt show up when trying to update using SD Card. It still does give option which firmware to update but no box for PDF and PS. Only PCL and PS Font.
    Below was the romdata that I put into SD Card
    FWUMODULEID11: MEC21Ae_printer
    FWUPIECEMARK11: D0AD5570N
    FWUVERSION11: 1.13
    FWUINFORMATION11: Printer
    FWUMODULEID12: METC21d_prt_RCS
    FWUPIECEMARK12: D0AD5571D
    FWUVERSION12: 3.18.39
    FWUINFORMATION12: RPCS
    FWUMODULEID13: MEC21d_prt_IPS3
    FWUPIECEMARK13: D0AF5572A
    FWUVERSION13: 1.02
    FWUINFORMATION13: IRIPS PS3
    FWUMODULEID14: MEC21d_prt_IPDF
    FWUPIECEMARK14: D0AF5574N
    FWUVERSION14: 1.15
    FWUINFORMATION14: IRIPS PDF
    FWUMODULEID15: MEC21e_prt_IPDF
    FWUPIECEMARK15: D0AF5575N
    FWUVERSION15: 1.15
    FWUINFORMATION15: IRIPS PDF
    FWUMODULEID16: GW8d_ips_fntI
    FWUPIECEMARK16: D0AF5576A
    FWUVERSION16: 1.21
    FWUINFORMATION16: IRIPS Font
    FWUMODULEID17: GW8e_ips_fntI
    FWUPIECEMARK17: D0AF5577A
    FWUVERSION17: 1.15
    FWUINFORMATION17: IRIPS Font
    I already check "Extended Security" where update or changing firmware structure set to "Not Prohibit"
    Any help?
  • GIUBOSS
    • 1437
    I think you should update the entire firmware. Have you tried online? Is this a newly purchased machine from a dealer? Have you tried resetting it?
    • ccchuah
      • Mar 2009
      • 159
      If the machine have been install with postcript SD card ,after removing the PS3 SD card , the original PS and PDF will be missing, because the Ps3 card will replaced it after install
        • 37626
        Check that it actually is an ex model. If it has any other print options it most likely is not. From what I understand the MP C3504ex was a special model that came with PDF Direct and Post Script 3 factory installed and no other print options available. Someone may have put the wrong controller board in it. You need the part catalog that specifically shows it is for the ex model to be able to check the part number.
        • copier tech
          • 8219
          FWUVERSION11: 1.13
          FWUVERSION13: 1.02
          FWUVERSION14: 1.15
          FWUVERSION15: 1.15
          FWUVERSION16: 1.21
          FWUVERSION17: 1.15
          Any help?
          Try updating the firmware using the package file, this contains all necessary files.
          • Popolopo
            • May 2023
            • 143
            Did try update using Ricoh Firmware Update Tool and SD Card with the package. But it still the same.
            Nope. This one from random company decided to move out and let go their stuff.
            Not sure what you mean with resetting it? Is it memory clear?
            • Popolopo
              • May 2023
              • 143
              Think so. I want the emulation PS and PDF back. Not sure how to do it
              • Popolopo
                • May 2023
                • 143
                I did check the controller got sticker D0AD5681, I suppose that is the correct part number
                  • 37626
                  DOAD appears to be the correct machine code for a model in the ex series. I have dug a little deeper into what documentation I have access to and from the Printer Specifications available on Ricoh-USA it comes standard only with PCL5c, PCL6, PostScript®3™ Emulation, PDF Direct Print Emulation. I'm not certain how the emulation firmware will appear in the diagnostic report or if they are removed when the SD card option is installed.
                  Genuine Adobe® PostScript®3™, Adobe® PDF Direct Print​ are options requiring SD card to install.
                  • luca72
                    • Oct 2017
                    • 1792
                    FWUVERSION11: 1.13
                    FWUVERSION13: 1.02
                    FWUVERSION14: 1.15
                    FWUVERSION15: 1.15
                    FWUVERSION16: 1.21
                    FWUVERSION17: 1.15
                    Any help?
                    check with sp 5-990-"diagnostic report" a firmware presence
                    try SP 5-801-"printer" and reboot
                    "I'll be back"
                    • Popolopo
                      • May 2023
                      • 143
                      On 5-990-005, it doesnt show what version of the firmware for PS and PDF
                      But if I check firmware version inside user tool>administrator tool>firmware version, it show both are 1.0.0
                      Try memory clear for Printer Application, restart machine, still same. Update package/romdata again, still not showing up. Where when select option for romdata to install, it doesnt show firmware for PDF and PS.
                        • 37626
                        Does anything on 5-990-005 show that same version?
                        • Popolopo
                          • May 2023
                          • 143
                          Nope. It show PDF and PS, but blank on what version on it.
                            • 37626
                            I meat does it show that version number for anything. Sorry about not being clear.
                            • Popolopo
                              • May 2023
                              • 143
                              This is what 5-990-005 printout
