Ricoh mp c3003 , error
  • tullio
    • Feb 2012
    • 268
    while printing this message comes out. then it starts again. once a day.
  • 8T2
    • Aug 2015
    • 257
    Re: Ricoh mp c3003 , error
    What does the SMC report say?
    Sent from my SM-A305F using Tapatalk
    • tullio
      • Feb 2012
      • 268
      Sc hystory sc899.
      • 8T2
        • Aug 2015
        • 257
        Then my bet would be on out of date firmware. Someone probably trying to print something off the net for instance
        • dave w
          • Jun 2015
          • 230
          Yes my thoughts
          Printing a pdf via chrome is a possibilty
          • luca72
            • Oct 2017
            • 1784
            Originally posted by tullio
            [ATTACH=CONFIG]53233[/ATTACH]
            I would start by looking at the simplest things, that is to say, some drum, or development group, or motor (however) "hard" to turn, simple test that you can do with your hands, it has often happened to me that blocking an engine (even maybe cleaning with the rag, I pressed too hard during rotation) ... anyway look at the smc
            "I'll be back"
              • 37532
              SC 899 often caused by trying to print something like an Odds sheet or a playoff brackets sheet from a questionable web site. Sheet contains a Trojan that is downloaded could install all sorts of malware When you try printing it straight frokm the website, the unrecognized code causes an error in processing in the print engine. Ergo SC 899. Try print from Print Preview. That "flattens" the page removing all non-printable code. Can also print troublesome PDF from print preview.
              • sandmanmac
                • 3981
                Sc hystory sc899.
                There must be 50 threads on this forum relating to SC899 on a multitude of models.....How about trying SOMETHING FOR YOURSELF for once, and read a few of them!!!!
                  • 37532
                  And if you read through the Firmware History bulletin, close to that many fixes for the 03s.
                  • GIUBOSS
                    • 1436
                    It is much less demanding to ask than to seek
                    • Tony in Oz
                      • Dec 2021
                      • 13
                      Update Firmware & print driver
                      had many '03' models do this
                      • copier tech
                        • 8172
                        Sc hystory sc899.
                        Very common issue on early METIS models. Unplug the network cable, update ALL the firmware, reconnect the LAN & get your client to run the same print job again.
                        Could also be a failing HDD but I'd start with the firmware.
